Results 3,971 to 3,980 of 6591
July 12th, 2009 08:37 AM #3971
mam, possible po talaga na sira na ang compressor ninyo. pero mam, have they checked na baka yun compressor clutch lang ang sira niya? pero mam, mura na kahit paano ang quote sa inyo kasi sa akin dati, super taga ang ginawa. clutch lang ng compressor, 4k na ang quote sa kin! kaso bumigay din. at ang ending ko, brand new compressor na taga rin!
hmmmmm, patulan mo na taz yun kyb. yan din ang shocks ko ngayon. kung sa ball joints, pareho kami ng stand ni pb, sa oem kami. yan ang unang unang ginawa ko sa pajero ko nung binili namin. palit ako ng lower ball joints at upper suspension arm. bakit, kasi yung mga bushing at shafts nun, may kalog na kaya buong upper suspension arm assembly ang pinalit. oem lahat yan kaso may kamahalan nga lang
pb, salamat sa comment... pero problema ko na ngayon dyan, dami na gasgas...:sad:
July 12th, 2009 10:32 AM #3972
PB, thanks dun sa Q ko about sa BFG tires
Guys ask ko lang.
magkano ba 4m40 na surplus? baka kasya sa trooper
- Apr 2009
- 7
July 12th, 2009 12:43 PM #3973Hi sirs!
I got my Pajero from Subic
it's a 1996 Exceed with 2.800 Diesel Engine A/T.
Sirs, since I am a newbie, I humbly ask for your assistance with my Pajero.
It has a lot of problems. Any suggestions would be very very much welcome.
Problems:
1. Sunroof leak: Motor not working properly also. Do you know where I can have this fixed po?
2. Camber misaligned and Matagtag: I think i need to have the shock absorbers and springs changed. Do you know any local surplus shop where I can have it fixed po?
3. Power steering fluid leak: I am having problems with this every month. I have to put fluid once a month kasi nauubos.
4. Electricals and Airconditioning: The switches near the headunit for the aircone and other dials like the compass are not working... anyone knows where i can get a cheap/pulido na fix?
THANK YOU THANK YOU in Advance!
Looking forward po.
- Aug 2006
- 121
July 12th, 2009 01:09 PM #3974this pajero is just so nice. wow! san nyo po nakuha yung fender side mirror?
- Apr 2008
- 210
July 12th, 2009 04:40 PM #3975tnx testy, talagang medyo madugong gastusan ito....hehehehe
kelan ba luwas ni PB dito sa manila? parang may nabasa ako na sabay sabay sila magpapalit ng leds, sana pwede kami manood parang mini EB na rin.
July 12th, 2009 06:40 PM #3976
hello sir, jdm pajero owner din po ako and same model sa inyo. so sagutin ko mga queries nyo to the best that i can po...
1. recently ko lang din na-encounter ang problem sa leaking sunroof. what i did, binuksan namin ng erpats ko ang sunroof at nilinis ang passageways niya at yun drain niya. sundot sundot lang naman yun and clogging ang problem nito dahil madumi na. pero as for the motor, i had mine working very fine. baklasin nyo po yun ceiling niya, andun po ang motor at pwede nyo i-check yun
2. try also checking your ball joints and bushings sir. i had mine replaced 2 months after i acquired my pajero. puro oem ang pinalit ko.
3. hmmmm, eto din ang isa sa mga problema ko noon. ano ang dahilan? o-ring... yan ang madalas na problema niyan sir. pag nagawa niyo na yan, the last thing to check is the steering gearbox kung may leak na mga oil seals niya
4. yun compass ko, hindi na working. hindi namin ma-trace kung maling electrical wiring lang o defective talaga. kasi ang ilaw para dun eh hindi rin nagana nung binaklas namin, pero buo pa yun bulb ah. at dun sa aircon, its the climate controller po yun. dapat working yan kasi pag hindi, wala kang aircon. describe nyo nga po sa akin yun problem about that...
- Jun 2009
- 12
July 12th, 2009 07:38 PM #3977thanks testament for your comment.
anyway, wala sya sinabi about sa clutch..ung sa compressor na daw tlga papalitan. I went to other shop also yesterday, sbi nya ung compressor reading daw e nsa 90 na supposed to be 40 lng kya dapat daw palitan na tlga compressor? every kelan ba dapat lagyan ng oil compressor para nde mag stuck up?
thanks
July 12th, 2009 08:04 PM #3978
TAZ13,
my suspension is also due for repairs and replacement thus I also did some canvassing. hope this helps you in comparing the prices since your post helped me gauge the pricing.
this is from my previous post:
"fellow tsikoteers,
I recently had my rig's suspension checked (gen2 pajero swb) and since then have had trouble deciding on which course of action to take.
option 1 (autoshop along regalado)
use replacement parts and replace the worn out parts here is their quote:
2pcs ball joint upper - 1900
2pcs ball joint lower - 2200
4pcs suspension bushings - 2200
2pcs suspension bushings lower - 1600
2 sets wheel bearings - 2400
labor for balljoint - 1700
labor for bushings - 1500
labor for wheel bearings - 1000
wheel alignment and camber adjustment - 900
option 2 (cruven)
"inject" or recondition the OEM suspension parts on my rig to brand new specs daw. they quoted the ff:
4 balljoint (inject) - 2200
4 Tie rod end (inject) - 1800
1 pitman arm (inject) - 450
4 upper suspension bushings (replacement) - 2600
2 velocity grease - 200
4 wheel bearing - 3800
labor for front suspension - 1500
labor for press in press out - 400
labor for wheel bearing - 1200
wheel alignment - 400
cleaning - 100 (should be free as a standard IMO)
so there, with this data please help me decide on which option to go by.
are this prices reasonable?
and if any of you knows a more affordable way to go through with this please free to chime in.
TIA"
July 12th, 2009 08:07 PM #3979
July 12th, 2009 09:32 PM #3980
how old na po ba yun sasakyan ninyo mam? maybe its time na to replace its compressor na din po, baka hindi na maganda ang performance niya. suggest ko lang po mam, better invest po on a brand new compressor. matagal naman po ang buhay nun. ingat nga lang po sa price niya ah...
How about 97 LXi?
Civic horsepower
