Results 3,871 to 3,880 of 6591
July 1st, 2009 08:13 AM #3871
July 1st, 2009 08:16 AM #3872
AC,
i know you would have to take down the front skid plate to access the mounting for the chrome plate below the grill. matrabaho and you will have to get dirty. but relatively easy. fiberglass ok lang, im more worried about the wiring harness for the foglights that you will be installing.
- Jul 2008
- 33
July 1st, 2009 11:17 AM #3873http://www.carchrome.co.uk/pajero-co...b-set-94-p.asp
larshell icopy mo to then paste sa homa page d mo maaopen just by clicking here
- Jul 2008
- 33
July 1st, 2009 04:27 PM #3875
Hi,
I am just on the other room(strada), since I am already in the mits ground may I seek help or advice from you guys. I have my Fieldmaster 4x4, M/T,diesel for almost 6 years now, lately is my recent problem of hard starting every morning is persistent , I need to depressed fuel pedal several times before mag start, & the redondo of the starter is quite longer than before. I have changed the fuel pump already but the problem is still there. Pag nag start na wala ng problema, only during the initial start. I have not check the heater kung lahat ay gumagana pa.
Thanks for any inputs.
Rgds.,
RTS
- Jun 2007
- 81
July 1st, 2009 04:43 PM #3876hi, you may check first the glow plugs if they are still working. If busted na, then bili ka kahit hindi original (but original is better). After that, check your battery if ok pa. Based on my personal experience, glow plugs life is shortened by frequent off-on especially if cold pa ang engine. This happen if one-time cranking of the engine is not enough to start the engine, when your battery is not good.
July 1st, 2009 04:47 PM #3877
199 Off Road House in Tondo or other off-road shops with fabrication capabilities (e.g. Filmars - the Zuki specialist) can do it. You can choose to have only the front (the one you can see from the front) skidplate replaced or include the oil sump guard underneath.
OR, you could just scour the ads as some Subic units came with aftermarket skidplates and owners wanting to revert to 'original' look sell them off.
The headlamp mount for the center bumper meron yata sa C3 4x4 along Araneta avenue.
- Apr 2008
- 210
July 1st, 2009 09:48 PM #3878Good day to all, I am now a proud owner of a 2001 Pajero FM. Meron po ba club, if meron gusto ko po sana sumali. Mga sir 100t Km na pu ung pajero ko andi know na kailangan ko na po gawin ung mga necessary maintenance. Tanong ko lang po kung saan po ok magpapalit ng timing chain, water pump at ska po ung tensioner. Saka hingin ko na rin po advice nyo kung ano pa po ang kailangan ko gawin sa maintenance ng ride ko. Thank you po in advance.
July 2nd, 2009 06:07 AM #3879
larshell, will let you know kung naka order na ako. $1.30 lang each yung led. 2 pcs kailangan sa compass.
Taz13, replace all fluids and belts.
July 2nd, 2009 09:27 AM #3880
sir, welcome dito sa aming tambayan. timing chain, hindi mo kelangan palitan yan unless eh iba na ang tunong ng sasakyan mo. water pump, oo kelangan mo na palitan yan. pero check mo muna kung may kalog na siya o wala. like mine, bagong palit lang last week kasi may konting kalog na water pump ko. may pics ako from the previous page kung paano magpalit. as for the tensioner, you may or not change it. check mo muna kung maganda pa ang ikot ng tensioner mo. yung sa kin, eh ok pa naman ang ikot niya pero may plano na rin kami magpalit in due time.
kung club hinahanap mo, there is the Pajero Club of the Philippines or simply known as PCP. enjoy your new pajero sir!
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
