Page 335 of 660 FirstFirst ... 235285325331332333334335336337338339345385435 ... LastLast
Results 3,341 to 3,350 of 6591
    #3341
    Quote Originally Posted by RLX555 View Post
    hello Pajero gurus,
    1. Is it normal that in the morning and whenever maghapon nakapark, namamatay ang engine pagkastart kung hindi mo muna painitin ang engine. Yung aking kasi dapat apakan accelaretor up to 2000 rpm, pag umangat na temp, dun pala aayos ang andar. What could be wrong?
    nangyari na sakin to before. i changed the glow plugs(replacement), then the fuel filter and i had the injection pump calibrated. but i think the calibration really did the trick.
    i went to motorix last sunday pinacheck ko yung glow plugs. three are busted and only one is working. an oem glow plug costs about 2.4k at motorix. so it'll cost around 10k for the four. guys baka may alam kayong ibang shop na mura? i tried el dorado they sell it at 2.2k each. still too pricey for me.
    #3342
    yung sa akin din nung bagong kuha yung pajero ko. pachange oil ko sa casa, tapos nung pinapa-align ko, sinabi hindi pwede at pinakita sa akin, magalaw na ang fronts ko. so quoted sa akin, front suspension arm, lower ball joint, palitan na daw. ayun, inabot ako ng 14k para mapalitan ang mga yun. ngayon, ok na siya at 1 year na din ang nakakalipas.
    ang problema ko nalang eh yung post ko na pics at squeaking rear brakes
    Mar 2003
    #3343
    noxious, sa experience ko di talaga tumatagal oem glow plugs, 30 to 40k kms lang tinatagal, same lang din sa replacement, difference nila price replacement kitahara htk yata yung name. 320 lang per pc. ang mahal na pala ng oem plugs, dati kuha ko 1,200 lang isa.
    #3344
    promdiboy and noxious,
    maraming salamat sa quick reply.
    try ko pa check yung injection pump, hopefully this will do the trick.
    the best talaga itong forum na ito, I'm learning a lot from all of you guys.
    Try ko patignan yung mga concerns ko this weekend and I'll let you guys know kung may development.
    #3345
    Prepare ka ng 10-12K para sa injection pump kung overahaul at ~18K kung kasama yung injector sa overhaul. Quotation yan ng Central Diesel.
    #3346
    Quote Originally Posted by badongski View Post
    junkun13 try mo sa seatmate contact# 5322104
    ty sir! kaya din ba nila gumawa nang naputol na fin sa aircon?
    #3347
    kung hindi din tumatagal ang oem i might as well get the replacement nalang. anu bang pinaka-okay na brand kung replacement? P500 each sa el dorado yung replacement na sinasabi mo pb.
    Mar 2003
    #3348
    noxious, friend ko kasi yung owner dito sa amin baka kaya mas mura.
    Aug 2005
    #3349
    Mga gurus, ask ko lang opinion nyo or kung may experience sa problem na ito. Last wkend sa Baguio, I had eight adult passengers (ave Wt. 150lbs) with me plus baggages and kailangan ko mag reverse at an angle na wala pa siguro 20 deg. Hirap na hirap umatras and pag tinodo ko sobra black smoke. Pero sa salunga naman sa Kennon kayang kaya kahit 2rd gear sa pinaka steep na inclination. Sa patag naman along SCTEX 120kph parang gusto pa.
    Salamat in advance.
    #3350
    eto ang problema ng aking steering gearbox...
    pb, tingin mo, bakit kaya? o-ring din kaya?
    Bro, parang nangyari na sa akin ang ganyang tagas, though hirap tingnan kasi sa picture lang.. Dati kasi akala ko gearbox din, nung pina check ko oil sending unit pala lang ang sira.. Try mo pa-check ang oil sending unit.. Sana yun lang din ang sira nyan para mura lang gastos mo.. 120php replacement, 320-400 yata ang oem.. labor 150 lang, dali lang din gawin yan kung yun ang sira.. After magawa yung sa akin, nagpa engine at underwash ako para makasiguro kung yun nga ang sira, mabuti naman at yun nga
