Page 334 of 660 FirstFirst ... 234284324330331332333334335336337338344384434 ... LastLast
Results 3,331 to 3,340 of 6591
    #3331
    hello Pajero gurus,
    I'm new in the forum, i just got my late 99 pajero fieldmaster, 4x4, A/T.
    It looks really gwapo, specially with its Euro look, no modification though, all stock except for ralli art rims.
    I have a few questions though...
    1. Is it normal that in the morning and whenever maghapon nakapark, namamatay ang engine pagkastart kung hindi mo muna painitin ang engine. Yung aking kasi dapat apakan accelaretor up to 2000 rpm, pag umangat na temp, dun pala aayos ang andar. What could be wrong?
    2.may squeeking sound pag nagbrake ako, manipis nqa kaya pads?
    3.parang kumakabig sa kanan, lalo na kapag nalubak, is this normal?
    thanks in advance... mabuti na lang may forum na ganito...
    Mar 2003
    #3332
    rlx555, welcome namin ang gwafu mong pajero,
    guess ko lang to,
    1. meron bang kasamang super itim na usok lapag napaandar mo? or pag start mo parang palyado? this could mean calibration na or may leak sa fuel lines. but pag ok naman lahat and no black smoke when you press the accelerator baka mababa lang ang minor mo, adjust lang dapat pag maiinit na nasa 750 to 800 rpm idle. tip ko llang dont step on the accelerator kapag malamig engine, wag sa 2k rpm, enough na siguro sa 900rpm
    (you can use thr throttle knob on your right knee) nasa baba pa lahat ng engine oil baka mag maaga mag wear out engine mo.
    2. try using oem pads kung squeek sound
    3. pag konting konti lang kabig baka sa kalye na yan, alignment lang katapat niyan. minsan dito lumalaki gastos kasi pag nagpa align ka, need nila check up front suspension and pag hindi pa nagagalaw yan usually may kailangan palitan munang ball joints, bushing or tie rod bago pwede ialign.
    #3333
    thanks sir PB.
    saan kaya makakabili ng K&N filter? magakano po kaya?
    wag po kayong magsasawa sa kakaadvice sa akin, maraming salamat.
    Aug 2007
    #3334
    Quote Originally Posted by RLX555 View Post
    hello Pajero gurus,
    Sir RLX555 welcome po.
    mga guru help naman po uli,,kasi yung unit ko may tok-tok sound , nadidinig ko sya pag dahan-dahan lalo n sa may humps..parang dun sya nanggagaling sa may unahan gulong sa kanan..ano po kaya sira nun..maraming salamat po
    Mar 2003
    #3335
    ikawngaba, bro front suspension yan, dami pwede panggalingan. the best talaga dalhin sa servitek yan para maangat, kung DIY gusto mo, hanap ka ng kasama ishake niya ng ishake yung kotse, para maglaro front suspension, (kung wala ka bumper overider, dun mo patapakin kasama mo and talon kamo or pwede rin open front door the tayo siya sa side and shake from left to right, pag sa likod madali lang eh tapak kalang sa rear tailgate. ) and hahanapin mo saan lalabas yung sound. areas to check, front suspension bushing, balljoints, shocks baka sira na or shock bushing. the last time nag tok tok yung pang ilalim ko was galing sa front right brake caliper. but this happens pag tapak ko ng brake pedal.
    rlx555, sa autocentro sa cubao ko nakuha, nalimot ko lang yung tindahan but naka post yan sa previous pages.
    Jan 2009
    #3336
    wow, tnx for all the quick replies. looks like the first thing to do is the oil light problem. it doesn't always happen and i just had it checked sa casa pero nothing about oil pressure problem tho i did not tell them about it (di ko pa masyadong napapansin nun since bago pa). also, nawawala sya pag i rev it up. what's the most likely possibility? i just had the oil changed to mobil 1 sa casa (heavy check-up). i got this at 750k. i will slowly follow your advices because i can only do it on weekends. i hope this can be fixed soon coz we plan to travel to ilocos during the holy week. BTW the brake squeak happens when i start pressing the brake and about to stop, esp in the morning (as i've said, kakalinis lang and makapal pa).
    Mar 2003
    #3337
    egsunio, kung bumababa idle mo ng sobrang baba. iilaw talaga yan, tuwing kailan umiilaw? maybe mababa masyado idle. sa brake problem mo wala naman problem diyan. medyo nuisance lang yang sound dahil pag metallic ang pads talagang may konting squeel. ganyan din akin dati nung naka bendix ako, pinalitan ko din agad, sayang ang arrive ng pajero kung pag preno natin, squeeellll.
    #3338
    Quote Originally Posted by junkun13 View Post
    mga sir san po ba nakakabili nong parang wood na sticker sa fieldmaster?
    like this:
    nagasgas kasi yong isang part sa paj namin, na tuluan nang air freshener
    up ulit, thanks
    Dec 2008
    #3339
    junkun13 try mo sa seatmate contact# 5322104
    Jul 2005
    #3340
    hello Pajero gurus,
    Experienced squeaking sound before pero nung pinacheck ko sa Speedyfix, makapal pa daw. Recently lang I had them checked again and manipis na... So I, had them replaced with Bendix brake pads and nawala naman ang sound (so far).
    Sa akin din dati kumakabig pakanan pero maski hindi nalubak. Dinala ko sa Servitek Q. Ave for alignment pero may tama na daw tie rod, ball joint etc. So pinalitan na din.
