Page 173 of 660 FirstFirst ... 73123163169170171172173174175176177183223273 ... LastLast
Results 1,721 to 1,730 of 6591
    Apr 2006
    #1721
    yan na nga ang pinagtataka ko eh.....what could be the cause nung pagka baliktad niya...
    Mar 2003
    #1722
    hindi kaya jdm unit mo?
    May 2005
    #1723
    Quote Originally Posted by rtp View Post
    One way of checking if your unit is a JDM is your plate. If 96 it should start with U if local but if JDM plate start w/ X or R
    Mar 2007
    #1724
    Mga Pards, patulong naman. Hindi kasi bumubusina yung 99 Fieldmaster ko thru my steering wheel horn pad at napilitan muna akong magpakabit ng temporay wiring at push button sa left side ng dashboard para lang may magamit ako. Medyo cautious kasing gumalaw ang mga Technicians dito sa amin sa Batangas City kasi delikado daw dahil nung airbag. They're suspecting na sira na yung lock spring inside the steering wheel and I have to replace the airbag assembly which is costly. I have yet to prove this kasi nga ay di ko pa napapabuksan yung steering wirings. I'm hoping na may na-disconnect lang or something.
    I want to retain yung safety ng airbag and humanap ng possibilities na magagawa ito ng di masyadong costly. Plano kong lumuwas next week at maghanap ng pupwedeng mag-troubleshoot o mag-repair. Any idea mga Sirs kung saan ko siya pwedeng dalhin dyan sa Manila (Evanagelista or Banawe?). Maraming salamat po.
    #1725
    Quote Originally Posted by Piraeus View Post
    Mga Pards, patulong naman. Hindi kasi bumubusina yung 99 Fieldmaster ko thru my steering wheel horn pad at napilitan muna akong magpakabit ng temporay wiring at push button sa left side ng dashboard para lang may magamit ako....
    Piraeus, Nawalan din ako ng busina 6 months ago on my 99Fieldmaster. But when it happens kasabay iyon ng pag pula ng SRS indicator sa dashboard. What we found is that the electrical assembly that connect the horn and airbag was cut open. The assembly is like a wounded flexible wiring with multiple strand. The electrician can no longer repair the cut so i have to buy the assembly at El Dorado for 7K pesos. Just bring your ride to experienced electrician and they should know what to do. Yes, do not attempt to remove it yourself as the airbag might explode.
    #1726
    Quote Originally Posted by pajerokid View Post
    By the way PB, yung door/courtesy lamps na try mo na palitan with the LED type? i changed mine yesterday ANG GANDA and ANG LAKAS!!! fuse bulb type siya pero may 4 LEDs and circuit board na maliit. Aliw na aliw ako! Since LED ito, i assume di na mapupundi (unless masira yung circuit board hehe).... also hindi umiinit kahit nakabukas yung pinto ng matagal.
    Master PK - May nag-alok sa akin nang ganyan sa Banawe kanina pero medyo pricey at 720 pesos per door. So 1440 for pair of front door. Ganun din ba ang kuha mo?
    #1727
    anyone here who still has their used and broken old oem front shocks? baka meron sa inyo? buy ko sana yung bushing sa lower part. may play kasi shocks ko. nagtanong na ako sa casa, cant buy the bushing only. buong shocks daw dapat. I'm willing to pick up at your place, pa PM nalang kung meron thanks po.
    PB - Kailangan mo ba ito? My old OEM stock is still in the garage... i have my shock replaced to OME 4 months ago.
    #1728
    heres mine, 99 model, but ginawa kong new STOCK look.orig bumper overider, foglamps, rims and sticker, muntik ko na kagatin sa casa dati yung 10k for the sticker only, buti nalang nakakita si PK ng mas mura sa winterpine.
    PB - How much winterpine sold door-side sticker?
    Mar 2003
    #1729
    cargoboy, sayang nahuli na, thanks sa offer bro, nagpafabricate na kasi ako ng new bushing, pa PM naman saan location mo and how much mo benta?
    sa sticker 3.5k or 4k yata kuha ko, not sure kung tama alala ko, basta naalala ko binanggit ko si PK kaya nagless pa ng 500.
    kung may family ka US meron ako nabili na LED 150 pesos each lang, 9 leds siya. ganito gamit ko, Attachment 9949
    May 2007
    #1730
    Ask ko lang, mey sira kasi un antenna ng aming Pajero 2.5nd Gen. It doesn't fully retract all the way down, which should be when you turn off the vehicle. Dun sa Paj namin, it just stops midway, but you can still hear the motor of the antenna running.
    ANo kaya parts involve dito, and magkano at saan kaya ok paayos un ganitong problem? For those who had similar problems, please share naman kayo about it.. Thanks fellow tsikoteros!
