Results 141 to 150 of 615
- Aug 2010
- 2
January 19th, 2012 06:12 PM #142
January 19th, 2012 07:55 PM #143
sir gamen, i sent you copy of the alarm manual
January 19th, 2012 08:18 PM #144
- Feb 2011
- 1
February 6th, 2012 12:44 AM #146
The add-on alarm takes the signal from the stock keyless entry system. However, the stock ekeyless entry signaling turns off once the ignition is at on. Hence it cannot be reprogrammed with the buttons. Found this out by probing the pins. (i do have a little car electronics know how to substantiate my findings). So what I did: brought my car to the winter pine service center along aurora, had them reprogram the alarm module. They have a programming jig. So they will have to remove the unit from your vehicle to do just that. Had them change options 15 and 16. Silent unlock and park lights light up. Left item 14 lock chirp on since I need that to locate my vehicle in a a sea of cars whenever I park in large parking lots. Done in less than 20mins. Handed the tech a tip.
Hope this helps
- Feb 2012
- 1
February 26th, 2012 01:39 PM #147same prob with obfree sir. was trying to reprogram the alarm para maging silent but to no avail. isn't there any other way? thanks
- Mar 2012
- 1
March 26th, 2012 06:24 AM #148Hi all if someone has a manual for gls-v alarm manual kindly send it to my email ryane516*gmail.com thank you.
- Dec 2011
- 1
March 27th, 2012 10:28 PM #149I'd appreciate it if somebody could email me the manual too. Thanks. - legalcounsel*su.edu.ph
- Apr 2012
- 113
April 28th, 2012 08:14 PM #150pls someone email me a manual too....thanks,,,randy_napster*yahoo.com
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
