Results 31 to 40 of 43
January 19th, 2004 04:24 PM #31
Dapat yata mabuway hindi taubin. Pag nadaanan ng truck o bus sa gilid buong body nadadala ng hangin.
- 441
January 19th, 2004 11:11 PM #32otep,
oic,so malamang same din sila ng rear shocks ng gen1,ang hirap kce bumili ng parts minsan pag walang sample eh,eh the unit is on our prov. kelangan pang mag padala ng sample if ever.
- Jul 2010
- 1
July 24th, 2010 08:40 AM #33Helo, im new here, and just got our delica star wagon about a month ago, it was in great condition, until recently na discover namin na nagleak ang power steering fluid, had it checked and sabi na ang leak is from the rack and pinion assembly ng delica... nagtanong tanong ako sa ibang mekanik and surplus shop, ang sabi nila samin is that since and delica ay converted RHD to LHD, and rack and pinion assembly nito ay possibly from other brand like nissan or toyota... any delica experts there know about this things?
- Mar 2010
- 21
July 26th, 2010 10:57 PM #34sa mga delica owner (spacegear or starwagon) try nyo ang forum na delicaclub.com
sa australia ito.sikat ang deli doon.maraming tips doon tungkol sa maintenance and repair. nandoon na din ang mga parts number.
July 29th, 2010 11:35 AM #35
But i guess the problem won't just solve it that easy? kase diba converted ang mga Delica dito sa atin.. Just like sir malmangbata said, possibly, parts from different brand might have been used on Delica's convertion..
I have a colleague who's got a Delica din, Yun din ang problem niya same with sir malamangbata. Ewan ko lang kung pano na-solved problem niya. Palagay ko kayang kaya makahanap niyan sa Pasay..(?)
July 29th, 2010 11:48 AM #36
Sir sure ka rack and pinion? truck based yan and it usually uses a recirculating ball & nut? if its a leak it must be an oil seal... kung yun nga me oil seal centre like Simplex on 6th ave. cor avenida Kalookan which has all kinds of oil seals. I got mine there when I had my steering box repaired. I wouldn't buy a surplus for that, its a wear and tear item. When you have the sample, bring it there or call them to make sure they have stock, if they dont I think they can fabricate you one but it has a minimum of 3 pcs order yata.
- Mar 2010
- 21
August 2nd, 2010 11:08 PM #37my deli is a series 1 4m40 auto exceed.
nakapag inspect na ako ng steering mechanism nya.rack and pinion sya. malapit sa toyota hi-ace ang parts nya.nung nag palit ako,pinakita ko sa auto supply ang sample. pang toyota nga ang rack end at tie rod.may makukuhang parts nito sa banawe (gilid nga lang).
- Mar 2010
- 21
August 2nd, 2010 11:23 PM #38
suggestion lang:
pa check mo agad ang brakes na apat.disk brake lahat na yan. tignan mo ang pads at kung gumagalaw pa ang caliper.prone kasi sa seizure ang mga yan.
palitan nyo na din agad ang plastic na expansion tank ng radiator.usually 10 years lang yan at kailangan palitan.prone ka sa over heat pag hindi mo na plitan.mga 6k yan sa el dorado.pag bukas mo ng hood ay malapit yan sa preno.may radiator cap.distilled water ang ilagay para hindi kalawangin.
pa check din ang alternator kung malakas pang kumarga
sa ilalim ng blower ng intercooler ay lagyan mo ng pading ang upper radiator hose para hindi mabutas.
i block mo ang egr(exhaust gas recirculation).lagyan mo lang ng plates.hindi kailangan yan sa pinas.at para lalong gumnda takbo.nasa exhaust manifold yon malapit sa turbo
paminsan minsan ay i engage mo ang 4wd nyang 3(super selct,hi,lo).para hindi mag stuck up. yung hi at lo setting ay bawal gamitin sa semento at aspalto o matigas na daan.masisira ang transmission
sana makatulong sa iyo
- Mar 2010
- 21
August 2nd, 2010 11:28 PM #39
- Sep 2008
- 630
November 3rd, 2010 11:46 AM #40Hello,
Tatanong ko lang po, kung okay lang po ba palitan ng mas maliit na gulong ang delica para hindi siya mataas, what specs of tires should be used and the pros and cons of changing the tires. TIA!
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
