Results 1 to 4 of 4
- Oct 2010
- 3
October 25th, 2010 04:40 PM #1may itatanong lang po ako..... yung adventure ko po ay 2002 model po super sports... kasi po napapansin ko hirap po ung sasakyan ko maka 120 po ang takbo... then meron din po akong nararamdaman na pag 120 po ung takbo ng sasakyan nag vibrate po ung sasakyan ko... sana po may maka2long sa kin
October 25th, 2010 05:15 PM #2
alaga ba sa change oil Adventure mo?
Vibrate at high speed? Baka camber/alignment lang maka sagod dyan. Ganyan din Adventure ko dati, or di pantay na upod ng gulong (still due to toe in curable by camber/alignment).
- Oct 2010
- 9
October 25th, 2010 07:28 PM #3dati syang nag 120?
depende kasi yan kung may load (gaanong karami ang sakay);
if the wind is opposing your direction;
your fuel may not be the same as you used before;
your fuel strainer in the engine is getting clogged;
Your fuel filter is clogged.
Let's talk about the last - the strainer is located near the first injector (closest to you when you are facing the engine), you can either do this by yourself if you have the right wrench and a very small tip (long nosed) pliers. This is actually easy to do. Just be careful not to lose the spring, strainer, and 2 washers... this will give you the headache looking for them.
The strainer is very small so be very careful.
Wash this with gasoline and high pressure air compressor... be carefull not to let go.
Then check your maintenance checklist when you last changed your fuel filter... To my experience, cleaning the strainer is normally done first, and tested for power before changing fuel filter which is more expensive. But then again, soon you will have to change fuel filter, so better put the date on your next change.
Changing fuel filter means you have to go to the shop.
Let me know if it helps.
- Oct 2010
- 9
October 25th, 2010 07:36 PM #4When in comes to vibration at high speed,
Take your vehicle to a tire shop and have it wheel balanced.
You see, tires are not perfect, and so are your rims. In time rims get exposed on uneven roads, rocks, and load of your vehicle.
And in time, balancers that are attached during the initial balancing gets lost (they are just glued). Have it balanced.
Also, check if your tires doesn't have a bubble, or unevenly worn out...
Definitely the vibration will come from the two front tires, so have them rotated (front goes to the back) do not rotate by switching left to right. If you will do this you will have to take the tire off the rim and invert it so that the wear of your tire goes outward (thus will save you some few months).
Bottomline... have it wheel balanced.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
