Results 201 to 210 of 211
- Jun 2015
- 2,751
June 30th, 2022 05:14 PM #202Maybe underinflated tires? Sa HB ko naman magaan pa rin 34 psi at makapal pa ang tread.
Also, how's your tail/brakelight? It might sound unrelated but I've heard of some issues that were miraculously solved after replacing a busted brakelight.
Social media made y'all way too comfortable with disrespecting people and not getting punched in the face for it. - Mike Tyson
- May 2018
- 2
July 7th, 2022 03:12 PM #203I think I still have the factory tires, and 35 psi all around naman. Although recently I had both rear tires patched kasi napako. The heftiness of the steering isn't really affecting my driving. I feel like I'm just nitpicking.
'Yun din ang iniisip ko lalo na these are factory tires pa.
They're 35 psi all around. I had a busted brake light pero got it replaced already.
Thanks everyone for the response. I tried multi-quoting but for some reason I can't figure it out for the life of me.
- Jul 2016
- 761
August 30th, 2022 12:18 PM #204Sira kaya yung lock sa kaliwang rear door ng mirage hatchback namin? ayaw gumana unless manually siya ilock at unlock. Naka deactivate naman din childlock. Tunog nga ng tunog alarm pag binuksan from the outside kasi di naglolock unless i manually lock mo sa loob. May sira ba yun o may namali lang ng setting or whatever mga magkano paayos nun kung sakali
- 52,524
August 30th, 2022 12:24 PM #205my two guesses,
a connecting rod/plate dis-connected; or
the solenoid/motor ain't working.
you will have to open that door and find out.
it's not that difficult, if one is comfortable doing that sort of activity.
once opened, it's pretty straightforward common-sense troubleshooting.
bring it to the mekanikos, if you prefer.
my 2003 lancer cedia once had the same problem.
the mekaniko replaced the actuating motor with a surplus unit. (motor pa noon, hindi solenoid.)Last edited by dr. d; August 30th, 2022 at 12:33 PM.
- Jun 2011
- 1,057
November 23rd, 2023 08:54 AM #206Aabot din pala ng 40k CVT repair (comments section). Clutch repair kit pa lang. Ok pa ang belt and pulley.
https://youtu.be/ycZNmlkIs3Y?feature=shared
- 52,524
November 23rd, 2023 01:15 PM #207
- Jun 2011
- 1,057
November 23rd, 2023 05:15 PM #208
- 52,524
November 23rd, 2023 09:54 PM #209
- Jun 2011
- 1,057
November 25th, 2023 12:12 AM #210Kaka iba iyon ah. May na stuck siguro sa loob dati.
Buti dumadami na din rebuild kit ng cvt ng common cars.
Sa lazada pulley and belt set nasa 24k. Remanufactured lang ang pulleys, mukhang ni reface.
TRANSPEED JF 15E RE F11A automatic transmission gear set with chain belt 9 1 68 9 1 72 Cvt pulley set for Nissan Mitsubishi suzuki car accessories [remanufactured] 29/3 Teeth | Lazada PH
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
