Results 1 to 8 of 8
May 25th, 2007 09:12 PM #1
mga sir,
may 03 adventure grand sport po kasi kami and napapansin ko po na kapag may nakasakay na sa 2nd and 3rd seat bumababa na po yng pwet nung kotse ano po ba pwede gawin??Pinagiisipan ko po kung pwede palitan ng RANCHO shocks??hindi kaya siya magiging matagtag??magiging stiff parin kaya yng oto and kung magkano at san po makakabili ng shocks?and kung pwede po yung shocks na yun sa adventure
May 26th, 2007 11:28 PM #2
Yung sa tita ko unat na ang leaf spring, I'm thinking of adding an add'l leaf spring in to it, yung sa 'min ayos lang ('97 model side swing type rear door) 'di masyado lundo ang pwet, mas matigas kasi leaf spring no'n eh try switching leaf springs or add add'l bottom leaf spring to keep it straight when loaded...
May 27th, 2007 11:41 AM #3
sir hindi po ba magiging masyadong matagtag yun kasdi po sabi nila yung mga ganyang model dw po ay medyo matagtag
May 27th, 2007 11:53 AM #4
basta di sagad yung shock, di yan tatag-tag.. so if you plan it to lift, say 2 inches--> dapat 4 inches longer sa original shock mo para may laro ang shocks...
May 27th, 2007 12:57 PM #5
afaik Shock absorber will only absorb shocks. it does not stop passengers weight.
I think replacing better spring is the best option.
if you plan to lift your vehicle, your shocks should be higher indeed.
but higher means more unstable ride.
May 27th, 2007 01:49 PM #6
2 inches pwede na yun.... palit ka springs sa likod/palitan mo ng hanger, sagad mo ang torsion bar sa harap, palitan mo ng shocks 2x the length ng tinaas mo-->1 inch=2 inches, 2 inch=4 inches para may laro yun shocks(di mag top/bottom-out agad. rancho na may 5 or 9 settings maganda..
BANNED BANNED BANNED
- 3,790
May 27th, 2007 03:59 PM #7I noticed that the last leaf of the leaf-spring in the Adventure was turned upside-down (naka baligtad).... why not have it turned over.
This technique is usually applied kung matigas yung rear... so binabaligtad yung last leaf... pero in the case of your adventure it is the other way around. It might become matagtag a bit than before but it would be able to have a better "load-handling" capability pagpuno ng pasahero.
May 28th, 2007 02:39 PM #8
thank you po sa mga replies niyo i gladlly appreciate it and saan po ba makakabili ng rancho na brand new and how much po.kasi meron po akong nakita sa mga surplasan na rancho shocks (sir papano po pala maglagay ng picture d2 hindi ko po kasi alam eh)
MotorImage?
Car Sales Data (2024)
