Page 194 of 203 FirstFirst ... 94144184190191192193194195196197198 ... LastLast
Results 1,931 to 1,940 of 2027
    #1931
    Quote Originally Posted by whilmeister View Post
    Thanks istan for the input. Another question, wala kasi ako alam na pwede pagdalhan ng kotse for check up..bakay may mairerecommend kayo na shop. I'm from Marikina, so let me know if may alam kayo malapit somewhere sa amin.
    Thanks.
    these things are easily fixed by any competent mekaniko, if you don't want to do it yourself.. what i do is go to the pasay rotonda or the paco herran auto supplies and ask the tambay mechanics there to do it. (i think those in paco charge less..)
    in marikina... naku.. wa akong alam diyan. siguro sa banawe na lang..
    Dec 2008
    #1932
    Hi guys, just want to ask regarding sa cvt fluid ng lancer. Planning to have it replaced sa casa kasi. Ang ginagawa ba nila dun ay drain and put the fluid or drain then flush, then if may dumi pa drain and flush uli? Ganun kasi (drain then flush) ginawa sa honda city namin at nawala yung jerk nia. Thanks guys
    #1933
    *whilmeister
    Bisita ka lng sa Banawe corner Agno. May shops jan ng Mitsubishi.
    Its near Q.Ave, side ng Sanctuarium (Araneta).
    Dec 2009
    #1934
    Quote Originally Posted by Blacknumenorean View Post
    Have it replaced by the Casa just for security purposes. I had mine done at the casa. But, as we all know, pricey* sa casa.
    *How pricey? Paki-tancha sir: Note that if you will have the casa replace your timing belt, they'll charge 9k flat (includes timing belt, camshaft/crankshaft oil seals, tensioner bearing). I made a canvas at El Dorado and ended up with around 5,500 including labor.
    Anyways, the CVT is a sensitive component, considering that it CVT mechanics with rebuilding kits are hard-to-find.
    Kagaya din siguro yan ng power steering: Drain-Flush-Refill. Pero sa case ng CVT, there is no visual indicator if the refill is clean. Sa power steering kasi, you can drain-refill until you can see the fluid as bright red.
    If your CVT is jerky, have you tried the P-R-N-D-N-R-P sequence? The jerking (on my experience) usually happens everytime I disconnect-connect the battery. Since the ECU has been reset, jerking will occur as it tries to calibrate the settings again.
    I hope that helps.
    Oct 2009
    #1935
    Quote Originally Posted by 0Glitch View Post
    I hope that helps.
    sir oglitch, ilan ang mileage mo nung nagpalit ka ng timing belt? sa akin kasi NASA 70k na and paano makapunta sa el dorado?
    Dec 2009
    #1936
    Quote Originally Posted by nyvlem View Post
    Di pa ako nagpapalit sir, sa November pa. By that time, I would be on 60-62k kms.
    El Dorado - Lampas lang ng SM Bicutan, across red ribbon. Search mo na lang site nila bro.
    Sabi ng casa, at 65k ginagawa yan. Pero dahil nga madami ako reasons for not going to casa, i'm doing it just below 65k kms. Also, daily drive ko ito so I'm sure, medyo laspag na si timing belt.
    Parang kailan lang ano? at naguusap tayo dito dahil bago pa mga lancer natin, ngayon nagkakamot na tayo ng ulo sa maintenance hahah.
    Oct 2009
    #1937
    haha.. Oo nga sir, nag expire na warranty nitong October Lang, ako din sir araw araw ko gamit, so far sir nasira sa akin yung shock sa likod and leak sa power steering, yung shock nacover ng warranty pero nag PMS Lang ako sa casa nung 1k and 5k Lang.. the rest sa labas na kinover pa din ng warranty hehe..pati aircon cleaning Hindi ko pa din ginagawa haha.. alaga ko Lang sa change oil, spark plugs and lagi linis ng air filter, and twice a week na vacuum ng car cabin... power steering leak, bumili Lang ako ng repair kit and yun ayos na.
    Dec 2009
    #1938
    Ano daw cause ng power steering fluid leak?
    1. Nag-change ka ba ng fluid before?
    2. Usually yan bumubula na pag pangit na fluid.
    Curious lang bro. Ano kwento nyang power steering mo? Thanks.
    Aircon cleaning malapit na ako, pero di sa casa. Alam mo naman kwento ko dyan na nasa history ng thread na to.
    Oct 2009
    #1939
    yung nabibili Lang sa blade yung ginamit ko na power steering fluid, once palang ako nagpalit, yung leakage naman, sabi nung nag show, oil seal Lang daw, at almost 70k na mileage normal Lang daw yun, ewan ko Lang kung binobola ako o Hindi, pero NASA 1.2k Lang yung repair kit, ngayon wala ng tagas
    Dec 2009
    #1940
    That's good to know bro. Thanks!
    Well, i can see some signs na madami na palitin sa lancer. Ganyan naman almost all cars when nearing warranty expiration, parang timebomb.
Lancer GLS/GLX CVT 1.6 2009 Owner post naman dito
