Page 188 of 203 FirstFirst ... 88138178184185186187188189190191192198 ... LastLast
Results 1,871 to 1,880 of 2027
    Dec 2009
    #1871
    Quote Originally Posted by gumburumbu View Post
    guys nu pala size ng bulb ng foglamps natin?
    Our foglamps are coded "H3", with a 55W rating. These are widely available in auto shops. Be careful on the Bosch brand since it has a different wattage rating.
    Apr 2010
    #1872
    mga sirs... mag pa 40,000KM PMS na ksi ako... i got a quote from Diamond Motors-Marcos Hi-Way... and cost is almost 20K with A/C cleaning na... advise naman mga sirs... need feedback po sana plus is Diamond Motors-Marcos Hi-way good service center? ung previous ko kc is Cabanatuan and Malolos but now I live near this service center... any help will be appreciated...thanks
    May 2012
    #1873
    hi everyone, habol ako. isa ko sa mga late na naka kuha ng lancer gls cvt. last May 17 lang. Just had my 1k PMS earlier sa Valle Verde ok naman service nila. mababait din pati SA. anyway, eto mga naging issues ko, may kroog kroog sound ako sa front left brake ko pero mukang naayos na ngayon. ang main issue ko nalang is FC, I actually read the thread from page 1 to 187.. weeks ko din bago natapos. lupit no? medyo baguhan kasi para di mapag iwanan sa information. going back sa issue ko, first full tank ko mga 100km pa lang ata ako nun, naka 320 km ako. while yun second ko 280 na lang. almost same lang naman route ko and tapak ko. ngayon parang un 9 lit. ko 60km lang. nabasa ko kasi yun iba nakaka 8 to 10 km manlang. right now, I am using regular oil and XCS din pinapa gas ko. ano ba mga dapat ko check? thank you!
    Dec 2009
    #1874
    Quote Originally Posted by ragedo95 View Post
    The FC depends on a lot of factors. The lancer is not good for city driving and but is really good at highway. Maybe you can try to lighten up your foot a little more and let the car accelerate at its own pace rather than forcing it. It really helps. (I'm not saying that you are a heavy-foot driver okay? I didn't see you saying these things kasi. )
    You are on CVT. The DS mode is guaranteed to eat up a lot of fuel.
    If you are doing a lot of uphill driving (carmona, antipolo, etc) that's another factor.
    Marami pa mag-babago dyan after 5000 km checkup bro.
    May 2012
    #1875
    thank you sir glitch! actually sobrang light pa nang tapak ko around 1.8 to 2.2/2.4 lang siguro un RPM ko. typical city driving lang din. pateros to taguig na 3 balikan sa office per day. ngayon parang okay un gas ko, unleaded sa petron. d muna ko nag xcs. experiment lang muna. nakaka 100km na ko sakto nasa 3/4 yun gas ko. ok na kaya yun? sagad un full tank ko last time.
    #1876
    I'd suggest do the full tank method.
    Full tank automatic, reset trip meter to zero, run run run pag nasa 1/4 nalang yung gas, full tank automatic ulit. Total kms ran/liters loaded=km/l consumption
    Dec 2009
    #1877
    You can refer to renzo_d10's suggestion. It's very simple.
    However, it is explicitly stated in the manual that the engine requires 95 RON (or higher) gas. Petron's Xtra Unleaded is 93. Di ba bumababa menor/rpm mo?
    May 2012
    #1878
    renzo_d10 - ganon na nga sir ginawa ko sa 3 full tank ko. thanks!
    May 2012
    #1879
    Quote Originally Posted by 0Glitch View Post
    thank you sa mga info sir. ganon nga ginawa ko kaya ko nasabi na nung una halos wala pang 6km per liter yun FC ko. ngayon sa tinatakbo ng gas gauge ko, siguro makaka 300km ako hangang umabot dun sa empty line. nag test lang din ako sa extra unleaded pero balik xcs din ako after. may malaking impact ba sa auto natin yun pag gas ko nang extra unleaded? yun menor ko ok pa din naman. medyo d ko pa ma differentiate sa xcs kasi saglit pa lang naman. thank you mga boss!
    May 2012
    #1880
    mga bossing, question lang. simula kasi kahapon, malakas kasi ulan diba. yun nag start ako ng engine ko, usually yung temperature ko napupunta agad sa gitna pero kahapon first time sya nag start na Cold tapos mga after 5 minutes na tumatakbo saka lang gumitna. okay lang ba yun? kanina kasi ganon din experience ko kaya habang cold engine pang tumatakbo kahit naka brake ako yun Rev ko 1.2 pa din. salamat po sa mga makaka sagot
Lancer GLS/GLX CVT 1.6 2009 Owner post naman dito
