Page 90 of 205 FirstFirst ... 4080868788899091929394100140190 ... LastLast
Results 891 to 900 of 2048
    May 2008
    #891
    Quote Originally Posted by babynos01 View Post
    goodafternoon guys. new member here and a montero sport owner.
    i would like to ask some questions lang.
    marami ba nakakaexperience ng rough downshifts (jerking) with strong 'clunk' sound?
    how about 'clunk' sound when accelerating from 20kph?
    thanks.
    Pabalik mo sa casa. Unusual yan. ASAP
    May 2008
    #892
    Quote Originally Posted by KC Montero View Post
    I have problem with lamp sa loob ng car, its not shutting off even when i lock all the doors. and the horn still works even the keys were removed. I have a GLSV, anyone have this same problem? Thanks!
    Hmmm... electrical wiring or computer program yan. Bring it back sa casa.
    Sep 2011
    #893
    ilang beses ko na inibalik sa CASA sir pero wala naman daw sila makita sa MUT. yung 'clunk' sound when accelerating from 20kph was caused by backlash daw. but when the car was new, i dont remeber hearing it e. according to them, backlash was at 1.9mm which is within the 5mm max value.
    regarding the 'rough downshift' with clunk sound, i still experience it.
    there are owners in this thread who also experience that.
    luigitiu
    heuer77
    jjgf
    thank you sir.
    May 2008
    #894
    luigitiu
    heuer77
    jjgf
    thank you sir.
    Bring it to Casa C-5. Look for ronie
    Sep 2011
    #895
    thank you sir. i'll try to bring it there.
    #896
    For the cabin light, try to play with the switch, tatlong mode kasi ang switch nyan.
    For the horn, normal yata sa monty yan na gumagana ang horn kahit naka off ang switch.
    Dec 2009
    #897
    Pre ganyan din yung sa akin akala ko may problema may delay yung lamp ng montero hindi gaya so kotse pag sara ng pinto off agad ang ilaw ng sa monty kung hindi ako nagkakamali parang 10-15 seconds bago mamatay dahan dahan payan kaya huwag kang mag alalala normal daw yan sabi sa casa tungkol naman sa horn kahit hugutin mo susi gumagana parin yan pero hindi ibig sabihin ma drain ang battery mo.
    Sep 2011
    #898
    Medyo mas matindi ang naging sira ng MS ko. I posted on another thread. Yung clunking on deceleration nangyayari sa akin. It happens from 40kph to 30kph. Right at 30kph...with jerking and thud.
    "...In December 2009 I got my Mitsubishi Montero 2010. In the last week of January 2010 I traveled to Angeles City. Nothing serious, went through Angeles traffic, visited a satellite office, parked in the basement, etc. Going back to Manila on NLEX I could not go beyond 60kph because I was hearing metal to metal grinding in the rear. Obviously this was a rear assembly problem. Diamond Motors confirmed that the differentials have failed. A month old but NEW car with a differential problem sounds crazy and extraordinary. It calls for a replacement.
    So they fixed it. The problem was there was a lot of performance issues, clicking/tucking sound beneath (loose U-joint), shift shocks etc. after it was done. A lot of business days wasted going to and from the dealer. No loaner car given. It looks like they nailed it last month when the Montero that I drive everyday seems to be running smoothly except for the shift shock abnormality from time to time. It is always good if you know that Mitsubishi plant engineers (the chief and senior ones) do the work - a little quality there.
    But one thing they never fixed was the annoying humming sound at 75kph to 90kph. It stops at 90. The sound is high pitched, high frequency so you can hear it with stereos on. It only goes when you press the pedal. I've been waiting for Mitsubishi Thailand responses because they "referred" it to them but still NO action. All research tells us that it is still a rear axle/differntial problem from the pinion to the rear wheels. The car is going to be 2 yrs old in 3 months.
    Anybody having this problem? Advice? ................."
    Read more: http://tsikot.com/forums/mitsubishi-...#ixzz1YZFlCaXR
    May 2008
    #899
    ask for replacement
    Apr 2011
    #900
    Hi sirs,
    Brought my Monty to Baguio and passed Marcos highway then suddenly nagrev up siya around 3k rpm.
    I understand na steep yung road kaya ganun but when I reached a flat road ganun pa din. It stays at second gear so umaabot sa 3.5k rpm na kahit gamitin ko yung paddle shifters until second gear lang.
    So what I did I shifted to "n" then "d" ulit. Ok na yung engine pero nauulit Pag steep na ulit....
    Has anyone experienced this? Normal ba or may problem yung car? Thanks!!!
ISSUES FOR THE MONTERO SPORT. Please post them here.
