Results 811 to 820 of 2048
- Jul 2011
- 15
August 2nd, 2011 11:52 PM #812
If you haven't yet seen this site, you may want to get in touch and share info with fellow MS owners with possible similar issue with what you experienced with your MS: Mitsubishi Montero Sudden Acceleration Accidents
7 reported cases already at the site. Your case makes 8, and if the fellow MS owner you mentioned is yet another case, not yet listed in the site, then that could be 9.
August 3rd, 2011 12:13 AM #813
Yes, this should always be a possibility in cases like these. The other possibility being some sort of momentary electronics failure.
Assuming all cases were driver errors, question is why the current pattern with the MS, than other models? Is there some lack of driver error proofing in the MS design, that other models have?
August 3rd, 2011 02:42 AM #814
data is from top gear
incidents is from that reported in this thread
but let's tweak a bit
lets assume 50 incidents. and to give a bit of accuracy, lets say 200 monteros have been sold from jan 2011 - jul 2011
so this means:
total MS sales 2009 and 2010 - 20,339 (top gear data)
total MS sales jan - jul 2011- 200 (assumption)
total MS sales to date - 20,539
total incidents of sudden acceleration/brake problems - 50 (assumption)
percentage of total incidents to total MS sales - .002% (rounded off)
so far, based on this thread, there are 9 incidents
paabutin muna natin ng 50 para magiging .002% and assuming sales of the MS have stagnated at 200 units by then
- May 2008
- 290
August 3rd, 2011 11:31 AM #815The percentage maybe too small but if it is true that this is computer glitch then are we going to just accept it as is without negligent liability? In law, a peron may commit a criminal negligence or a crime at 0.0002% in his lifetime but he will not be exempted from the liability if he commits it. A crime is a crime. A liability is a liability regardless of its significance.
My point is that if this is a product defect, not human error, Mitsu must be held accountable.
Your point is that because the incidents are too small in percentage, the cause is human error. Fallacy!! It does not follow.
- May 2008
- 290
August 3rd, 2011 11:35 AM #816
- May 2008
- 290
August 3rd, 2011 11:57 AM #817
Tsikot Member Rank 4
- Jan 2003
- 2,979
August 3rd, 2011 12:48 PM #818almost a year with my MS, wala na yun thug sound na nararamdaman ko.
headlight moist happens during heavy rains
experienced the same thing with aircon as sir easyman3. (twice only)
backing sensor does not beep unless very near na yun obstacle.
Other issue would be engine is much noisier after change oil with casa pero baka issue with oil yun, since mukhang mas ok yun ginamit ko na oil sa pajero (repsol)
August 3rd, 2011 03:13 PM #819
while i sympathize with all those who have problems with their montys and by all means i would even raise hell with the dealer/manufacturer, the data i showed simply tells me that this is not a widespread problem nor does it point to any lemon/manufacturing issue worthy of a recall.
the data tilts towards driver error or failure to understand the transmission system of the invecs II engine
as for me, i have no problems with my unit, plain and simple
i hope that those who have problems will be able to resolve this but until then, i am fully satisfied and safe driving my monty
August 3rd, 2011 04:34 PM #820
what i meant on that is the engine has started and the driver shift from park to neutral and he thought to have shifted to neutral but he/she accidentally engaged in drive position. now, he tried to warm up by revving the engine causing a sudden forward motion and makes the driver panicked. beside, brake system not working???? assuming, a sudden acceleration happened and he stepped hard on the brakes, the front tire must have hold or not turning while the rear tire must be spinning hard enable the vehicle to move forward. question, how can a vehicle have enough momentum in short distance inflict a great damage. sir, i hope that's the reason of sudden acceleration. unless there's something wrong with the engine and brake system (electrical, mechanical and electronics).
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
