Page 68 of 205 FirstFirst ... 185864656667686970717278118168 ... LastLast
Results 671 to 680 of 2048
    #671
    Quote Originally Posted by dbhollanda View Post
    sana nga ganon pero based sa actual experience ko lancer and adventure e once ginalaw ang oem at nagkabit ng accessories na gagalawin ang electrical e buong electrical void na warranty. lancer gsr 97 at adventure 2003 actual experience ko yan sa citimotors makati at union motors paco.
    i suggest tawagan ng TS yung dealer nya and ask to clarify para maliwanag.
    Just go to another dealer to get the work done. Don't bother calling the dealer. All they will say is VOID VOID VOID because they don't want to be accountable when you do a claim and you quote that you called ahead and talked to so and so and he said its ok.
    If you want to modify your ride, go ahead and proceed at your own risk. Better to enjoy your car than preserve it for the next owner [so long as you do not do mods that compromise operational safety and reliability].
    Or so long as you are confident enough to make a warranty claim in case something fails and you are positively sure its not because of your modification.
    May 2010
    #672
    I dont think so. As long as the cause of the damage is not connected or related to the accessory you installed, warranty still applies. Example, you installed HID and the electric wiring from your stereo going to your main supply had short circuited and your car was burned, the warranty still apply. Another example, if the wirring from your main power going to your HID burned and damaged your car, warranty is voided.
    Regardless of the writen provisions contrary to the above, the warrany still apply if the cause of damage is not because of your HID.
    Free legal advise.............heheheh
    Thanks for the Free Legal advise sir Easyman! hehehe....
    Aug 2010
    #673
    mga sir, ask ko lang, may problema kasi yung steering wheel ng montero gls se ko, bought it last june 2010, since then naka 2 palit na ko ng steering column assembly due to unusual sound when turning left or right,
    ano kaya solution dun?
    Jan 2003
    #674
    paanong unusual sound ba sa steering yan? baka naman hindi sa steering assembly ang problema?
    Nov 2006
    #675
    Same problem with my Mitsubishi Strada! Knocking sound / feel on steering wheel when turning left or right.
    Aug 2010
    #676
    after driving marikina - moa, moa - marikina, may naririnig akong eeeeee when turning left or right... ano kaya problema ng steering ko? 2 beses na ko nag palit with the span of 6 months
    Jun 2003
    #677
    Quote Originally Posted by igiwtf View Post
    Kung "eeee" sound, rack and pinion yan. Go to casa they should replace that.
    Yung "thud" or knocking sound, yung ang sa steering column.
    Aug 2010
    #678
    Quote Originally Posted by JACKSON View Post
    they keep on replacing my steering column, by the way, pang third time na papaltan yung steering column assembly ko next week, i should suggest to check the rack and pinion of the monty, thanks for answering sir,
    sa diamond motors corp marcos highway ko po dadalin
    Mar 2004
    #679
    nakakalungkot naman basahin yung mga bad experiences nyo sa MS considering mga brand new vehicles yan...
    honestly, nakakapag sisi ba na bumili kyo ng MS considering those issues?
    Aug 2010
    #680
    no, even though may issue yung unit ko,
    it's all worth having a monty!
ISSUES FOR THE MONTERO SPORT. Please post them here.
