Page 28 of 205 FirstFirst ... 182425262728293031323878128 ... LastLast
Results 271 to 280 of 2048
    May 2009
    #271
    ganyan din sa akin. parang nanginginig pag dahan-dahang pa-stop. basta ganun.
    hehehe... so parang lahat ng GLS SE yata.. tsk3. and pag release din ng brake. ganun din sayu sir?
    May 2009
    #272
    Same here. If i hit the brake pedal to slowly stop from high speed specially when road is wet (like when biglang preno sa harap), there is vibration on the pedal and rverbrates to the whole body. Lagi sa akin yan. aggresive driver ako sa highway at night.
    But since GLS SE has ABS and EBD, this one is normal. It is a balance between safety and comfort.
    Wiki answer.com says this::
    [SIZE=3]ABS [/SIZE]
    ABS: Antilock Brake System (or Anti-locking Brake System) - enables you to steer whilst keeping the brake pedal full on. Can be felt as a vibration through the pedal when it cuts in. Also useful in stopping in a straight line if one side is on slippery stuff and the other on grippy stuff (non-ABS will tend to spin).
    [SIZE=3]EBD [/SIZE]
    EBD: Electronic Brake Distribution (or Electronic Brake-force Distributor) - alters how much of the brake force goes to the front and how much to the rear. Cars always have more braking on front as if the rears lock before the front then the car will spin. How much braking you can do with the rears depends on how much weight is in the vehicle so EBD dynamically adjusts this balance. Without it, the manufacturer sets up the balance so the rears don't lock when the vehicle is empty which is less braking than is possible when the vehicle is full.
    The mpony manual for GLS SE has this:
    thanks sa reply and explaination sir.. hehehe
    May 2009
    #273
    Quote Originally Posted by JJGF View Post
    sir ito ba yung tik-tak-tik-tak-tik-tak? parang time bomb? kung yan nga sa alarm yan
    ayan may nakakapansin na pag takeoff meron ka din drag?
    ou, ganyan din sa kin.. ganyan din po ba sa inyu boss? mukhang marami pala tayo same issue. hehe
    #274
    Quote Originally Posted by Mconvert View Post
    1. Anyone having issues with the knocking sound on the steering wheel while turning left?
    Hi Mike Sir, i think your unit follows ching's and gixxer_50's. hope your dealer take a look and fixes it ASAP.
    Quote Originally Posted by nacastrence View Post
    anyone experiencing this? after driving my MS 3.2 what is the sound clicking on my engine? after mo gamitin tapos syempre papatayin yung engine there's this sound clicking loudly sa engine ano kaya yun? natural lang?
    and i've heard na dapat after using the MS dapat wag agad patayin because of the turbo masisira daw? eh sometimes i turn off the engine agad pagdating sa pupuntahan ko.
    Quote Originally Posted by luigitiu View Post
    I think it's normal because i've been hearing it since March pa and so far ganun pa rin
    May 2009
    #275
    sir while accelerating o pabagal? naexperience ko yan nung nagdownshift biglang "thug" while stepping sa gas pedal ng konti lang.
    ako baka 10 times na madalas sa paakyat ng parking sa mall
    meron din sa akin yan boss.. when you sudden step sa gas pedal from 20-40kph. parang 2nd gear pa sya. nag THUG din sya. para nga hindi brand new yung car dahil sa thug sound, nakaka iritate.
    #276
    pag jerking sa akyat ng ramp ng parking at condominium. pati pagaccelerate there is thug thing. especially if you try to sprint from stop.
    This is the reason according to Service Advisor: LSD (limitted slide differential).
    LSD plus ABS and EDB, naguguluhan na computer. not smooth at all.
    i don't think it's the LSD. My ride is 4x2, AFAIK, wala nitong feature sa akin.
    *JJGF
    I'm just cruising a smooth pavement flat for a constant speed of 60kph with my foot on the accelerator.
    Jun 2008
    #277
    di kaya sa turbo lang yan or sa catalytic converter?
    Nov 2006
    #278
    Quote Originally Posted by jeDi13 View Post
    hindi ba ganyan talaga sa lahat ng engines? i'm not sure if clicking sound or a liquid dripping and hitting a metal material. parang ganun, pero parang clicking nga yung sound. ganun naman yata sa lahat ng engines when turning it off after use.
    ganyan din experience ko sa xtrail for more than two years na. no issue naman daw sabi ng casa and so far wala naman untoward incidents.
    #279
    Pwede ba akong makisingit ng sagot being a former strada owner myself and having experience with auto trans vehicles.
    Yung tikitiktik sound after turning the engine off is normal. I've observed this too with my strada before and I think it has something to do with the contraction of metal parts during cooling. We know that metal expands when exposed to heat and contracts when cold. Since the engine is composed of several metal alloys, some would contract faster than the others. So, if two different and adjacent metal alloys contract during cooling, this may cause some friction and may emit the "tik" sound. Notice that it disappears a few minutes later.
    Yun namang "thug" sound during acceleration and deceleration, it could be due to "shift shock" of the automatic transmission, meaning, the gear downshifts or upshifts rather roughly. I noticed this to all my diesel A/Ts (my old frontier and my current everest) and it is observed at low gear shifting, between 1st and 2nd or between 2nd and 3rd. The higher gears would shift smoothly, though. Maybe, this could be due to the massive low rpm torque of diesels. I did not have this with my petrol cars (honda jazz and my present jimny). So sa tingin ko, normal lang ito for diesel A/Ts.
    Just my 2 centavos...
    Jun 2007
    #280
    i can hear that clicking sound on non-turbo cars after turning off the engine. i think it's normal. i can hear it on all our vehicles.
ISSUES FOR THE MONTERO SPORT. Please post them here.
