Results 261 to 270 of 2048
October 13th, 2009 11:47 PM #261
- Jun 2008
- 26
October 14th, 2009 01:10 AM #263
1. Anyone having issues with the knocking sound on the steering wheel while turning left?
- May 2008
- 290
October 14th, 2009 11:58 AM #264Same here. If i hit the brake pedal to slowly stop from high speed specially when road is wet (like when biglang preno sa harap), there is vibration on the pedal and rverbrates to the whole body. Lagi sa akin yan. aggresive driver ako sa highway at night.
But since GLS SE has ABS and EBD, this one is normal. It is a balance between safety and comfort.
Wiki answer.com says this::
[SIZE=3]ABS [/SIZE]
ABS: Antilock Brake System (or Anti-locking Brake System) - enables you to steer whilst keeping the brake pedal full on. Can be felt as a vibration through the pedal when it cuts in. Also useful in stopping in a straight line if one side is on slippery stuff and the other on grippy stuff (non-ABS will tend to spin).
[SIZE=3]EBD [/SIZE]
EBD: Electronic Brake Distribution (or Electronic Brake-force Distributor) - alters how much of the brake force goes to the front and how much to the rear. Cars always have more braking on front as if the rears lock before the front then the car will spin. How much braking you can do with the rears depends on how much weight is in the vehicle so EBD dynamically adjusts this balance. Without it, the manufacturer sets up the balance so the rears don't lock when the vehicle is empty which is less braking than is possible when the vehicle is full.
The mpony manual for GLS SE has this:
October 14th, 2009 12:28 PM #265
October 14th, 2009 12:49 PM #266
i experience the 'THUG' thing while cruising for a merely 60kph twice na. hope hindi ito big issue.
October 14th, 2009 12:54 PM #267
October 14th, 2009 12:59 PM #268
October 14th, 2009 01:00 PM #269
- May 2008
- 290
October 14th, 2009 01:40 PM #270
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
