Page 197 of 205 FirstFirst ... 97147187193194195196197198199200201 ... LastLast
Results 1,961 to 1,970 of 2048
    Aug 2008
    #1961
    Quote Originally Posted by 17Sphynx17 View Post
    After 9 years of ownership, only topped up with coolant twice I think. Once was a top up we personally did after seeing the levels drop, the other was done my MMPC Q Ave to change all fluids in the car if I'm not mistaken.
    Other than that, can't recall any instance of having to add coolant to the Montero (2011 VGT 4x2 model)
    Mileage right now is around 90k kms for that 9 year old Monty. Never topped up with water, just used Mitsubishi coolant mix only.
    May nakapag diy naba dito ng changing warer coolant sa radiator and block since ecq gusto ko sana mag diy palitan lahat ng coolant sa radiator and sa block.hindi ko kasi makita ung drain sa radiator block.pag nadrain na lahat palit lang ba or padaloy ng distilled water bago maglagay ng bagong coolant
    Jul 2012
    #1962
    i see, so yung unit mo belongs sa wala ng MAF. thats no a big deal naman. maybe the designers find it redundant or put a internal sensor somewhere to function the same.
    about sa rattling ng air duct, ganyan din sa unit ko dati, cable tie lang solusyon diyan. itali mo sa nearby sturdy component para hindi gumalaw at magkarattle. nakaangat kasi ng konti yung dulo sa ibabaw ng radiator cover. inserting a thin foam also helps, ensure lang na nakadikit maigi.
    rattling ng dashboard ay very irritating at mahirap mawala at saka if old na yung unit, what can you expect? nakukuha yan if binaklas ang dash and hindi naibalik ng maayos. any car audio shop with knowledge in car stereos can dismantle/reassemble and tighten loose parts if necessary.
    Yung montero 2012 ko ang rattling galing sa mga button switches ng mirror control sa left. Ang remedyo ko siningitan ko ng kaunting clear silicon sealant yung pagitan ng mga buttons at dash panel. Malambot naman ang silicon sealant kaya magagamit pa rin yung mga buttons.
    May 2011
    #1963
    Quote Originally Posted by GerryT247 View Post
    Velcro naman nilagay ko sa mga singit singit. Problem solved. Problem ko naman ngayon squeaky rubber door jam. Malangitngit sa uneven roads.
    Sent from my SM-G973F using Tapatalk
    Apr 2012
    #1964
    Quote Originally Posted by 3GEMS View Post
    baka makatulong ang spray ng WD40 bro[emoji6]
    Aug 2008
    #1965
    Ilan evaporator ng 2013 montero sports?dalawa ba?pag nagpa aircon cleaning ba baklas lahat ng dashboard?
    Apr 2012
    #1966
    Quote Originally Posted by lateral_link View Post
    2, isa sa loob ng dashboard at isa sa likod
    refer to this fellow montero owner video's. very informative, check part 1,2,3
    Paano Linisin ang Aircon Evaporator ng Iyong Sasakyan | Aircon Cleaning Part 4 | Complete Guide - YouTube
    Jan 2019
    #1967
    Mga ka monty mayroon na po ba nakagamit dito ng inhibitor switch na made in china, may nag offer po kasi na shop.. mas mura daw.[emoji32]
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    #1968
    Quote Originally Posted by adjong View Post
    kung ganyang electronic part I personally would not risk it. just for comparison i have used a few china some no name brand relay switches walang nagtatagal.
    #1969
    medyo ot lang.
    naalala ko yun aux fan motor ng 2nd gen montero namin noon conked out at around the 2 year mark.made in thailand i think. to be fair i've heard some units lasting longer than that. anyway pinalitan ko sya ng made in japan na orig motor(from a pajero ata) it was still working strong the day we sold it 5yrs or so after replacement
    Aug 2008
    #1970
    Mga ka monty good am. Question lang po baka may nakakita na sa inyo. Anong color ng factory or oem car stereo power socket sa montero 2013?ngaun kasi avt na technically aftermarket parin naman si avt diba. I bought kasi na new head unit sabi sa akin plug and play. Pero nung connect ko na yung sa power hindi kasya maliit yung kasama ng new head unit. So i was thinking na ung avt dati eh naka tap sa factory wiring harness not sure though. Thanks in advance
ISSUES FOR THE MONTERO SPORT. Please post them here.
