Results 1,931 to 1,940 of 2048
- Apr 2007
- 487
March 4th, 2020 07:30 PM #1931
- Aug 2008
- 26
March 9th, 2020 08:49 AM #1932Aircon issues need help.yesterday medyo natraffic ako on the way sa qc.medyo walang lamig ung aircon.pero pagpasok namin ng nlex at continous na yung flow andar lumamig naman agad.ano kaya problem kulang sa freon? Isa pa po recommended coolant po?50-50 mix or 70-30? And usually anong intervals pinapalitan yung coolant?
- May 2016
- 546
March 9th, 2020 09:51 AM #1933
- Aug 2008
- 26
March 9th, 2020 09:55 AM #1934
March 9th, 2020 10:21 AM #1935
ganyan din naging problema ko dati and most likely tama si bro lakwatsero re the wonky aux fan. iyong course of action ay pinalitan lang iyong motor ng aux fan. may replacement at oem motors & i chose the latter. kung tama pagkaka-alala ko 3k ata iyong orig na motor while iyong replacement kalahati lang ng price nung genuine stuff.
doon naman sa coolant, sa casa ka na lang bumili para walang agam-agam. basically pareho lang naman price ng mga aftermarket pre-mixed coolantsLast edited by baludoy; March 9th, 2020 at 10:30 AM.
- Aug 2008
- 26
March 9th, 2020 10:28 AM #1936
Thanks po sa reply.randam na kasi summet kaya pachange ko na motor.by the adding additional fan kaya mas ok din sa radiator.
Re coolant may makuhanan naman ako 1k 4L sa suking mitsu dealer.thanks. mga 8plus liters yung sa glx 2013 na monty noh.since 2nd hand ko sta nakuha i drain ko nalang lahat.
Salamat mga pafs.new owner ng monty at diesel car eh
- May 2016
- 546
March 9th, 2020 12:58 PM #1937Sakit talaga ng Montero auxiliary fan. Ok yung additional aux fan, pa install mo lang sa qualified auto electrical. Majority of vehicle fires, maling wiring ang cause.
Pa check mo na rin timing belt, ATF, brake fluid, oil. Recommended sa oil 6 months interval, wag na paabutin 10k or 1 year. Sa fuel, wag mo rin hayaan bumaba ng 1/4. Pag parati ubos ang fuel tank, pwersado fuel pump humigop. High pressure fuel pump ng diesel, madugo palitan.
- Aug 2008
- 26
March 9th, 2020 10:00 PM #1938Thank you sa mga advise sir. so far ang di ko na pa nagawa sa car is yung pagpalit ng fluid ng power steering,coolant change,rear drum break medyo nipis na raw.fuel filter change pero may reserba na ako.hehehe.pag clean ng fuel lines siguro kung neede ba?tas ung sa aircon po mukhang malinis nnaan kasi nagkabit din ako cabin filter.maram salamat sir lakwatsero.pag naka fully synthetic oil po ba 6 months lang?thanks
- May 2017
- 2,128
March 9th, 2020 10:22 PM #1939
- May 2017
- 2,128
March 9th, 2020 10:28 PM #1940
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
