Results 1,901 to 1,910 of 2048
- Jan 2019
- 25
February 2nd, 2020 07:56 PM #1901Mga bossing Montero 2011 may tagas ang power steering pump, may nabibili po bang repair kit. TIA.
Sent from my MI MAX 2 using Tapatalk
- Jan 2020
- 3
- Jul 2017
- 102
February 2nd, 2020 10:51 PM #1903
- Jul 2017
- 102
February 2nd, 2020 11:02 PM #1904
- Jan 2019
- 25
February 3rd, 2020 09:02 AM #1905
- Feb 2020
- 1
February 14th, 2020 10:38 AM #1906Good day mga sir. 1st time ko lang dito sa tsikot.
Nabili namin montero 2017 glx m/t ng 2nd hand. Wala naman problem sa reverse lights and gumagana yung rear camera. Pero ngayon kasi yung reverse lights di na umilaw and yung rear cam di na rin nagsshow sa HU. Unang experience kasi hindi iilaw reverse light then "No video signal" yung nasa HU. tapos neutral ko then balik reverse magiging ok naman na iilaw tapos naka display na yung sa rear camera pero ngayon di na talaga nagwwork ang reverse lights and rear camera. Concerned lang ako kasi kahit naka on hazard lights, di alam ng iba motorist pag nag rereverse ako.
Na check ko na kasi fuse pero hindi naman busted. Hehe
Would appreciate your advice mga sir. TIA
- 54,293
February 14th, 2020 10:41 AM #1907i don't monty,
my guess is, the back-up switch.
alas, i do not know where yours is.
in some cars kasi, it is DIY-easy to replace.
but i do not know how to explain the "no video signal" thing.Last edited by dr. d; February 14th, 2020 at 10:44 AM.
- Jul 2017
- 102
February 14th, 2020 11:20 AM #1908Gberto, better bring it to casa or your trusted mechanic. It will not cost you much and for safety,too.
Tama si Doc, meron yan sersor/switch doon sa transmission that detect if the gear is in R position.
It will trigger to send signal and voltage supply to the reverse light and usually the revrse camera voltage supply
is connected to the wiring of revese light. Na check mo na na okay yung fuse at bulb,that its not busted. Pero kung
meron ka multi-tester(i hope you know how to use) maaring walang voltahe yung reverse even na shift mo sa R.
Try also to check kung naka display sa dashboard ang R if you shift to reverse ( not sure kung meron sa GLX model).
- Mar 2017
- 29
February 19th, 2020 06:27 PM #1909san makakabili and murang labor for rack end pinion. nagpacheck ako sa marcos hiway may tagas daw. 3500 parts 6k labor.
- Dec 2015
- 183
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
