Page 154 of 205 FirstFirst ... 54104144150151152153154155156157158164204 ... LastLast
Results 1,531 to 1,540 of 2048
    Aug 2015
    #1531
    Mga boss, yung montero namin ang dalas mag overheat. Tubig, radiator, fan ayos naman and ginawa na rin namin 2 ang fan ganun pa rin. Ano kaya pwedeng cause ng overheat? Madalas to lalo na pag traffic ng todo
    Mar 2013
    #1532
    Quote Originally Posted by krypt09 View Post
    Check mo ang radiator cap.
    Nov 2011
    #1533
    ^pati silicon oil ng clutch fan
    Dec 2009
    #1534
    check mo radiator cap if functioning normally.
    check mo din thermostat mo kung nag o-open pa nang full-lift.
    check your clutch fan for excessive slippage.
    Aug 2015
    #1535
    Salamat sa reply mga boss. Check namin mga sinabi niyo
    Feb 2009
    #1536
    If ok ang radiator cap at di nagbabawas ng tubig...no leaks...check water circulating pump. Baka di na nagcicirculate cooling jacket water.
    Mar 2015
    #1537
    Quote Originally Posted by soypusoy View Post
    Ganyan din ako nung una dinala ko sa casa ganun daw talaga,pero sa timpla lang ng pag bitaw ng clutch at accelerator,ngayon di na gumaganon kasi kabisado ko na
    4yrs gap kasi d ako nkpag drive ulit...kapain ko na lng tamang timpla ng accel at clutch sa corresponding speed and gear...heheheheh...anyway thanks sa info sir atleast i know d ako ngiisa....
    Apr 2009
    #1538
    Hi sir,
    Hope everything is okay with your monty..
    Apr 2009
    #1539
    Quote Originally Posted by benny View Post
    Help naman, sirs. I bought on 09 GTV 6 months ago and had been very happy with it. 2 weeks ago, the airbag icon lit up persistently. I brought it to Amcar Sta Rosa. After 3 days, they said they didn't have the tool to fix it. I then brought it to Citimotors Alabang. They replaced the clock spring which they initially said was the problem, but it didn't help. After 3 days, they said they didn't have the "test part" to fix the fault since they said that even if my unit was locally purchased, it was sourced from Ukraine and not Thailand. Now I'm afraid all my airbags wouldn't work in case, God forbid, I get into an accident. I hope you have any leads on how I should proceed? Thanks.
    Hi sir,
    Mar 2015
    #1540
    Mga sirs any on encountered TPMS error? paano ito isolve? 2015 GLX M/T 5K palang thanks in advance
ISSUES FOR THE MONTERO SPORT. Please post them here.
