Page 127 of 205 FirstFirst ... 2777117123124125126127128129130131137177 ... LastLast
Results 1,261 to 1,270 of 2048
    Apr 2014
    #1261
    My 5 month old GLX's aircon is now not blowing cold air, just warm air. Should i bring it sa Casa or sa air con specialist? Kasama din ba yun sa warranty?
    Posted via Tsikot Mobile App
    Mar 2004
    #1262
    ^^^ It's included in warranty, you should read the manual given to you.
    #1263
    Quote Originally Posted by Renski0731 View Post
    Baka naman sir ung gauge nalagay sa kulay red.iinit talaga un.
    #1264
    Quote Originally Posted by vanguard14 View Post
    Good morning... my monty's 12v socket / cigarette port just decided to stop working. What would you think is the most likely cause? Is this something I can fix myself or would it warrant a visit to the casa?
    Tingnan mo sir mga fuse.nakalagay dun cigarette.baka sira na.
    Aug 2007
    #1265
    I have a brand new Montero GLS V. Sept 03, 2014 lang siya nakuha from Diamond Greenhills pero ngayon may erratic no crank no start na siyang problema. Thursday naranasan ko na siya one time pero simula kagabi till today, 99% no crank.
    Ano kaya possible causes?
    We've done the following:
    - baka daw low batt/dead batt, we tried jumpering it to a good batt. still no crank... sa tingin ko ok ang batt niya dahil malakas naman ilaw, gumagana radio, busina, etc..
    - baka daw dahil sa key immobilizer, we tried using the spare key and still no crank...
    - make sure na naka "park", we tried moving the tranny to both N and P, just the same no crank... kahit saan position.
    Di na siya magamit, nakakabwisit.
    Jun 2014
    #1266
    sir bannatiran ipa tow mo sa casa on their expense kasi napaka bago pa nyan para magka problema ng ganyan
    #1267
    Quote Originally Posted by bannatiran View Post
    Nakapa-bago nyan Sir bannatiran,
    Not sure kung sa AT version ay kailangan ba i-step yung brake pedal for start-up? kasi sa ibang sasakyan, kailangan tapakan yung brake para maka-start yung engine.
    Sa MT version, start sya kahit hindi tapakan yung brake/clutch.
    dapat i-delay kaunti yung pag-start, may heater ang monty, at least mga 5secs.
    kung wala talaga, patawag kayo ng mechanic from mitsubishi, kung kaya nila i-troubleshoot sa location nyo, kung talagang hindi mapapa-andar, no choice, pa-tow na agad, saka under warranty naman yan sir..
    Feb 2014
    #1268
    No need na tapakan ung brake para mag start basta nasa P sya. . .
    Apr 2012
    #1269
    paki-try mo sir isara mabuti yung rear door. nung bago pa monty ko one time di ko mapaandar at yan ang cause
    considering bago yung unit mo, wala pa dapat problem sa battery. but check mo rin baka yun ang problem. try mo salpakan ng similar battery kung meron ka other car o mahiraman saglit...
    Aug 2007
    #1270
    last night ayaw niya mag crank kahit anong gawin ko. this morning pagkagising ko, tried it one click start. ginamit ko siya, then another one click start. pinark ko ulit tapos kumain for lunch. after nun ayaw na naman mag crank.
ISSUES FOR THE MONTERO SPORT. Please post them here.
