Results 11 to 19 of 19
- Jul 2017
- 102
August 30th, 2018 02:31 PM #11Yes.. kahit nasa idle ka pag engine support may problem lalo na pag nag turrn on/engage ng AC.
Have you tried the first comment of dr d? what's your front tire pressure?
any significant difference in steering vibration while driving at asphalt and cemented road?
Also check yung pag lock ng steering adjustment.
- Jun 2018
- 31
August 31st, 2018 12:06 AM #12Front tire pressure is usually at 28. Let me try to observe the rest. Pacheck ko na siguro suspension system sa harap. May nakapagsabi din sa fb, same issue daw sa kanya ang ang problem is steering column.
- Jul 2017
- 102
August 31st, 2018 11:37 AM #13[QUOTE=Cccj;3001676]Front tire pressure is usually at 28. Let me try to observe the rest. Pacheck ko na siguro suspension system sa harap. May nakapagsabi din sa fb, same issue daw sa kanya ang ang problem is steering column.[/QUOTE
The tire pressure is okay... just bring to a good/reliable shop, co'z some shop would try to replace almost all your suspension
components, but could not pin point the main cause. If you're tire is balanced, then possible its the rod end parts.
maybe you can try to rotate your tire from rear to front if still the same condition.
If the steering vibrations happens once you stepping the brake, something wrong with brake rotor/pad.
Anyway just my opinion, usually I do a tried to narrow the possible cause before to bring to a shop especially
if its not known to me.
- Jun 2018
- 31
August 31st, 2018 11:43 AM #14Thanks. Most likely has nothing to do with breaks. It's a constant vibration while running and I can easily feel the bumps
- Jan 2013
- 686
August 31st, 2018 02:41 PM #15
- Jun 2018
- 31
August 31st, 2018 02:44 PM #16Thanks. What I recently observed is that the vibration depends on the road condition. If it's a well built asphalt, no vibration at all. Still steering column po?
- Jun 2018
- 1,475
August 31st, 2018 02:53 PM #17
- Jan 2013
- 686
August 31st, 2018 02:55 PM #18
- Jun 2018
- 31
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
