Results 21 to 25 of 25
March 26th, 2007 08:11 AM #21
sir mcclement thank you so much sa info. medyo confused pa ako kasi first time ko gagawin. pero try ko pag-aralan. kasi may dalwang thick wire nakasa suksok dun sa may engine near the injectors. so kailangan palang tanggalin yung cover nung mga cylinders ba para makita yung glow plug? ito yung cover kung saan located ang oil cap di ba?
- Feb 2007
- 46
March 28th, 2007 12:40 AM #22I think you're referring to the valve cover sir yung may oil cap. Di na tatanggalin yun sir.
Check out this link sir:
http://img238.imageshack.us/img238/9...lowplughq7.jpg
Meron ako nilagay na 4 red dots dyan. Yan sir ang glow plugs ng MMC 4D56 (4D55), just beside the valve cover and the injectors. The 4 glow plugs are connected in series by a thin aluminum flat bar that serves as its wire. Aside from that meron pa pong nakadugtong na thick wire dyan (maaring yun po ang nakita nyo) para mag-supply ng electricity sa glow plugs. Gamitan nyo nalang cguro ng sockets (size 8 for the nuts holding the wire/s and 10 for the glow plug itself, not sure dun sa socket size pro paki-check nalang) with socket extension para madali nyo matanggal.Disconnect the battery nalang po before removing the glow plugs kc yung thin aluminum flat bar po that connects to all glow plugs is a postive wire so anything metal that touches it and at the same time touching any other metal part of the engine will short and blow your fuse/relay with the ignition turned on.
March 28th, 2007 08:30 AM #23
again sir maraming salamat po sa info. this is very helpful. ang laking bagay. now everything is clear. sa may bandang gilid lang pala yun. sige gagawin ko na to sa weekend.
- Feb 2007
- 46
March 31st, 2007 01:44 PM #24Sir yun pala sa starter problem nyo pag mahina ang redondo palitan nyo na yung 2 brass bushings na humahawak sa armature. Kung maigsi na yung carbon/copper brushes nya palitan narin. Kung puro click naman lagi ang nangyayari pro malakas ang redondo di nyo na kelangan bukasan ang starter. Lagyan nyo nalang ng relay yung solenoid ng starter. Bale i-tap nyo dun sa malaking live(galing/nakakabit sa battery),positive wire ng starter yung source/inlet ng relay tapos yung outlet nya naka-tap sa solenoid. Yung trigger naman ng relay nakakabit yung isa sa ground and yung isa dun sa manipis na wire (na galing sa ignition swtich) na nakakabit dati sa solenoid ng starter. Bale ang mangyayari is, pag turn nyo sa START position ng ignition switch, pupunta yung kuryente (ng ignition switch) sa relay; pag-ON ng relay, iko-connect nya yung kuryente na manggagaling sa malaking live,positive wire ng starter papunta sa solenoid ng starter, para buong-buo yung kuryente na mapunta sa solenoid and goodbye to clicks ng starter. Ganyan din ang nangyari sakin di ko ba alam parang madali na mag-wearout ang mga ignition switch ng mga oto ngayon kaya kinukulang ng kuryente ang solenoid ng starter and puro click lang ng click. Dami ko narin narinig na ganyang cases.
April 8th, 2007 12:21 AM #25
I do DIY lang kapag may problema ako sa hard starting. 02 model advie ko and so far ang problem nya kapag ganuon, its either low bat or busted glow plugs. Replace ko lang 4 glow plug then back to normal na ulit
Corolla Cross 1.8G kumpleto sa active at passive safety. Wala nga lang advanced driver assist. ...
First time buyer, owner, driver. What to buy?
