Results 1 to 10 of 10
- Dec 2002
- 49
May 6th, 2003 09:31 AM #1Peeps!
My 3dr Paje which I acquired sometime in Nov 2001 has been having this problem. Maingay ang tranny kapag naka-idle. Nawawala naman siya kapag tumapak ka na sa clutch.
Nagsimula siya na nag slide yung clutch ko. Siyempre, palit lining, pressure plate and release bearing. After nun, hayun na, lumabas na itong tunog. Perhaps coincidence lang. Mula nun, may ipina machine shop sa fly wheel, napalitan na rin lahat ng bearings, pati sa shifter, may nai pa machine shop na rin dahil kapag idinidiin mo siya nawawala rin yung tunog, pero ganun pa rin. Dalawang beses na rin napalitan ang clutch lining.
What to do? Nakaka 6,300 na ako and the sound is still there.
Meron po ba kayong mai-re-refer na magaling na shop para matingnan naman itong aking sasakyan?
Suko na yung mekaniko ko e. Ang reco niyo, hanap na raw ako ng surplus tranny. V5MT1 ang code nung tranny.
Any help is very very much welcome.
Salamat poe.
May 6th, 2003 09:41 AM #2
Did you use OEM lining, pressure plate and release bearing? Did you check your pilot bearing? What model ( Gen1 or Gen2)diesel or gas?
- Dec 2002
- 49
May 6th, 2003 09:47 AM #3let me check on the brand used. come to think of it, i wasn't able to see it anymore. but if its any assurance, the one who did the job is a friend who would definitely replace the part if he declares he did replace that part. And yes, I forgot to mention, palit na rin pilot bearing. Gen 2 po this, diesel.
May 6th, 2003 10:10 AM #4
Noon nag palit ako was all replacement. After installing it may clinking, clank-clank sound. Sabi ng mechanic ko it will disappear (as in my other rides in the past). It didn't. So I reverted it back to the OEM pressure plate (still good !) , bought OEM clutch lining (really different in term of heavy duty use from the replacement) and OEM bearing. And the noise disappear after a little use. check also your crossjoint.
May 6th, 2003 12:23 PM #5
Meron din ride ko nyan kahit na bagong palit yung clutch release bearing. I tried to change the bearing part then after a week bumalik din agad yung sound.
May 6th, 2003 12:51 PM #6
Dalhin mo sa pinsan ni afrasay na si ferdie. Si afrasay powersteering god, si Ferdie transmission guru. :mrgreen:
- 267
May 6th, 2003 05:24 PM #7baka main drive bearing, dalin mo na sa expert like ferdie para di ka doble gastos. :D
May 7th, 2003 11:42 AM #8
usually replacement na pressure plate maingay.
ang ginagawa nila para malaman ito eh binabagsak sa sahig............ pag bagsak umalog ayun.
- Dec 2002
- 49
May 8th, 2003 04:13 PM #10
aewagon::: Mahirap hanapin si Mang Ferdie, mas mabuti pa hanapin mo muna si afrasay aka Boss Vic then sasamahan ka nya dun. :mrgreen:
