Results 1 to 4 of 4
March 28th, 2009 09:32 PM #1
mga sir ano kaya ang culprit nito nag byahe kasi ng nasugbu batangas ang L3 ko then pag balik sa akin medyo lumakas ang ingay ng engine at pag nag aacelerate ako nag vivibrate ang body? at may naririnig ako parang nag ggrind sa ilalim ng L3 ko? btw yung hatak normal lang po yung vibrate grinding lang ang nagkaruon?
March 28th, 2009 09:40 PM #2
hi sir- i hope this helps: its probably the engine mounts na po... a part of normal wear and tear perhaps lack of engine support can lead to a bigger allowance to move back and forth leading to the vibration ang grinding you mentioned po. thanks.
March 28th, 2009 10:48 PM #3
biglaan? naku baka minulto sasakyan nyo :peace:
seriously it must be the engine support. in other cars pag palit ng engine support ayun guminhawa ang buhay.
March 29th, 2009 10:41 AM #4
thanks ng marami mga sir yun din ang sabi ng mechanic ko engine support dalwa pala yun 700 petot ang isa bali 1.4k plus labor pa,,
yung kalansing na naririnig ko mukhang sa loob ng timing belt tensioner ata kaya pna check ko na ngayon
akala ko palyado na yung sasakyan
Suzuki JIMNY [merged threads]
