Results 1 to 4 of 4
- Apr 2009
- 2
April 24th, 2009 01:24 AM #1Just sign up informative ang site. Help lang po sa init engine ng L300, mainit ang driver seat ng 15 minutes drive plang nun brand new after 2 hours ngayon grabe na. lahat na insulation nagawa pero ganyan pa din. 4 years na sakyan din.
Thanks po.
April 24th, 2009 08:11 AM #2
Just a recommendation: (mine is an l300fb 1996 model)
1.) convert from vertical to horizontal mounting ang aircon evaporator para mas malakas ang air flow going to the radiator
2.) lagyan mo ng aux. Fan ang harap ng radiator (separate switch para may option ka when to use it)
3.) remove thermostat (sa may water pump)
4.) check ang water pump or replace if worn out
5.) ipa-overhaul mo ang radiator
6.) use a quality engine oil (10w/40)
7.) calibrate ang injection pump
8.) check clutch disc/clutch pressure (replace if worn out) usually kc pilit na pilit na makina with high rpm's eh ang takbo nahihirapan na maka-abot ng 90 or 100kph. (max 140)
9.) ipa-tune up baka masikip lang ang mga barbola
10.) timing belt
11.) replace air filter, fuel filter, oil filter, cylinder gasket
12.) last option if necessary...ipaoverhaul mo na engine nyan
- Apr 2009
- 2
April 25th, 2009 08:37 PM #3Thanks Zeus75. sa ibang nasabi mo okay naman na-check sya, sisimulan ko patingin ibang recommend mo lage nako check tsikot.com before type ko cars.ph un pala dito pla ang makakatulong. salamat uli
April 25th, 2009 11:48 PM #4
Do not remove the thermostat. Replace if worn out but don't operate the vehicle without it.
Without more context like when was the last time these items were serviced/replaced, it's hard to...
