Page 9 of 29 FirstFirst ... 567891011121319 ... LastLast
Results 81 to 90 of 281
    Mar 2003
    #81
    Pajerokid
    ano yung parang airfilter na maliit na nakakabit sa engine mo? ano purpose nun at malaki ba power gains?
    Mar 2003
    #82
    Sir otep
    gaano ba dapat kalayo ang average na tinatakbo ng diesel bago ma overhaul? sige try ko gawin yung washer na upgrade bukas, para lumakas pa ang hatak, aside from washer ano pa ba pwede gawin para bumilis? nakita ko sa pic ng engine ni pajerokid merong maliit na airfilter ok ba yun?
    #83
    PROMDIBOY,
    Depende iyan. Yung kay Pajerokid maaga niya napa-overhaul. Anyways, can afford naman siya. Right, Arman?
    Most diesels run into the 100K's before mangailangan ng overhaul.
    #84
    PROMDIBOY,
    The small air filter you see is a Breather Filter, yung exhaust gases that come from your cylinder head evaporated oil goes to your intake manifold, ibes na pumasok ulit sa engine nilalabas nalang nito sa atmosphere.
    If you want to gain more horspower try installing larger exhaust pipes and a free flow muffler, you can also install an open type filter like K&N for more breathing.
    #85
    Quote Originally Posted by OTEP
    PROMDIBOY,
    NYEK! 8O Wag kang maingay Otep baka may maniwala sayo! :lol:
    Mar 2003
    #86
    SIR YELLOW
    PWEDE ANG LAGYAN NG OPEN TYPE KNN FILTER PAJERO DIESEL????
    SIR PAJEROKID
    INGAT KA PALA NAUUSO NANAMAN KIDNAP FOR RANSOM.
    #87
    Paano malalaman kung sobra na boost at walang boost gauge?:?:
    #88
    the engine will overheat if there is too much boost. and sometimes if it is too much you will also lose power.
    #89
    Nakakasira po ba ng makina ang sobrang boost? :|
    #90
    PROMDIBOY,
    Pwedeng pwede yung akin and kay pajero kid naka open type cone filter.
Cranking up the boost on the 4D56TDIC
