Results 261 to 270 of 281
February 16th, 2009 11:57 PM #261
The plastic tube allows the Pajero to draw cooler air from outside the engine compartment (cooler air = more power). It also makes the Pajero more capable of fording water because it can still draw air from inside the fender should you encounter headlamp deep water. I have, and believe me, that plastic tube gave me the confidence to go on.
February 17th, 2009 12:22 AM #262
thank you sir Otep for the heads up, I thought it would make the airflow smoother, so although removing the plastic tube would allow more air in the intake it does suck in air heated by the engine....
I have actually tried this and noticed low end power loss (a bit) but my speed peaks faster at higher rpms. have not yet tried it at noon and heavy traffic though.
anybody familiar with the non muffler setup?
- Jun 2008
- 41
March 1st, 2009 10:49 AM #263Guys, I need ur help in this washer mod. Can you send me the pics for the procedure of the installation on a 4m40 engine kung meron po kayo.. sa email ko sana. shinnuker*yahoo.com
Thank you po.
- Apr 2010
- 4
April 3rd, 2010 07:03 PM #264Mga sir, gusto ko po i try ung mods sa washer/wastegate baka pwede po pa email ung pics and procedure. Thank you po.. mondpogs*yahoo.com
Tsikot Member Rank 4
- 2,719
April 7th, 2011 10:28 AM #266
check the 4d56 washer mod thread.
with pics and instruction na doon. Here is the link;
http://tsikot.yehey.com/forums/showthread.php?t=19903Fasten your seatbelt! Or else...Driven To Thrill!
April 7th, 2011 04:20 PM #268
Acts as a spacer/leverage para tumaas yung actuator, (thus increasing boost of the turbo once it kicks in). That is why you need a longer bolt na rin para same thread depth pa rin yung nakakapit sa turbo housing. If you use the same bolt, less part of the bolt is holding it down. Delikado IMO.Fasten your seatbelt! Or else...Driven To Thrill!
April 7th, 2011 05:15 PM #269
April 8th, 2011 01:28 AM #270
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
