Results 231 to 240 of 281
February 17th, 2005 10:35 AM #231
alwayz_yummy,
If I may humbly suggest... why not use the stock engine configuration and just cut a hole in the hood and put a hood scoop on.
February 17th, 2005 10:47 AM #232
can't po sir Pajerokid,delica po ride ko,e...kaya po problem talaga ang pag-run ng pipings,e..kaya ko po nasabing masmasikip pa sa L200 ang enginebay ko,e..
August 23rd, 2006 06:39 PM #233
can somebody post the pictures of the step by step procedure? hindi ko na ma-view ung pics doon sa 1st page eh. i want to try this with our Spacegear turbo diesel.
thanks...
August 24th, 2006 06:49 AM #234
the spacegear diesel uses the 4m40 right? here's some blurry pics that i posted when i did mine sa 4m40 namin. i might redo the pics soon pag nagka-oras ako. this should be the same in principle naman din for the 4d56.
http://mymitsuph.com/modules.php?nam...=1249&start=30
February 4th, 2007 12:07 PM #235
paano ba magmodify ng 4d56tdic, where ba put washer
cant find the picture, pls help
February 13th, 2007 10:24 PM #236
finally found the g-spot!!!!!!!! hahahahahahahaha!!!!!!
is installing three washer in 4d56 tdic still safe. since 8-24-2006 no one makes his reply feedback
February 14th, 2007 11:28 PM #237
i put three washer, , very responsive engine, he can push and carry the body weight of pajero with ease, unlike before the engine roar so loud when it hit 3k rpm, mabagal umarankada, now with washer mod, the engine roar lightly on 3k rpm, ratsada arankada!!
but im making it a point that i dont push my rev beyond 3k rpm i dont have boost guide, will it not result to engine damage????
big difference!!! you can feel it!!! yah!!!!!!!!
i try to do other modification by installing k & n filter, and put a breather to give the engine bloc immediately exhaust of gas/air or upgrade to a free flow muffler
March 9th, 2008 12:34 AM #238
mga boss pwede kaya ito sa 2C-turbo na townace? gusto ko sana subukan para mag increase naman kahit konti ang power nya
, kaya lang medyo madugo yung location ng can..
March 9th, 2008 09:26 AM #239
tech freak:
PM mo si RION dito sa tsikot... may townace siya nalagyan nya ng intercooler..ask him why...
as for the washer...had a 2c-turbo-e liteace 4wd. hirap lagyan ng washer ang wastegate kasi nasa may ilalim ng turbo hose, na natatakpan ng original driver-side seat..
so if you'll going to do this, i suggest, buy a boost controller nalang than the washer mod--sa hirap at daming baklasin maiirita ka lang...
dont know if my link in the sig still works, try mo lang, just to give you an idea anu itsura ng enginebay with the seats removed...Last edited by alwayz_yummy; March 9th, 2008 at 09:35 AM.
- Mar 2007
- 47
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
