Results 211 to 220 of 281
February 2nd, 2005 09:18 AM #211
not sure about the stock psi ng 4m40...but pwede naman deduce na two washers added made 11psi, added an extra washer and it made 12psi, so 1psi/washer and therefore, 9psi stock boost. boosting 14psi max ako through 5 washers, 15 pa nga spiking eh on 6 pero sumisingaw yung plumbing, or bumibitaw yung wastegate, dunno yet.
noteworthy: yup, dagdag maintenance.
falken: ahhh i see. alam ko merong clearer pic dito ng modification of washers. here's what i did, malabo lang nga kasi used a 3650 cellphone to take pix: http://mymitsuph.com/modules.php?nam...=1249&start=30
February 2nd, 2005 06:04 PM #212
makakatulong din po ba ang blanking of EGR valve, di ko lang alam mag attahced ng acrobat or image mula sa pc ko para makita kung paano.
February 2nd, 2005 07:17 PM #213
dabar, click mo yung 'post reply' button. It will allow you to attach a 600x400 pic.
February 3rd, 2005 05:54 AM #214
update ko lang po regarding running high boost...
i moved the intercooler intake clamp away from the end of the tubing (it's the tube which goes from the turbo to the intercooler), and i can now sustain 14psi boost for around 5-10 seconds, unlike before where i had actually put the clamp close to the end of the tube and when i try to boost 14psi sisingaw kagad. sumisingaw pa rin after around 5-10 seconds now pero at least i can sustain 14psi longer. i guess problem ko talaga was the plumbing, it was leaking somewhere...
February 7th, 2005 10:13 AM #215
what do you mean by the IC clamp? its the clamp that holds the tube?
February 9th, 2005 08:19 AM #216
yup!
i replaced the ic hose na, still same thing. baka nga may singaw somewhere, or compressor surge. oh well.
Tsikot Member Rank 4
- Feb 2004
- 1,704
February 9th, 2005 01:46 PM #218
sisingay siya if i suddenly go at least 80% WOT, 15psi peak then boost drops.
it doesn't happen actually if i graduallt go WOT, but in some cases (50/50 siguro), it'll have the same problem when the a/t upshifts
- Feb 2004
- 1,704
February 9th, 2005 03:54 PM #219gayahin mo na lang ginawa ni woodfire sa 4m40 niya, all stainless piping and those fancy blue elbows. maganda na, and most likely mawala ang singaw
andy
February 9th, 2005 04:28 PM #220
e ask ko lang mga sirs...
seen ko ung pics nitong modification...im wondering if the components shown may be identical sa 4d56t ng delica ko,including the location...
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
