Page 21 of 29 FirstFirst ... 11171819202122232425 ... LastLast
Results 201 to 210 of 281
    #201
    thanks sa feedback. i guess i'll go K&N na drop-in...and i might add another air intake tube that gets air from the grill area also.
    sakal kasi eh if stock i/h/e and boosting 12psi. the h/e setup will come later, along with change turbo.
    #202
    Actually, i dont think you'll need that extra intake tube since theres one already built in on the fender-side of the filter box. Kainis nga e, dust comes from said hole and dusts up a particular part of the filter.... hence the need to rotate every thousand or so kilometres. Eto reason for existence nung white plastic tube (with fins) in the stock air filter. It distributes the air coming from the hole instead of letting the filter suck it in directly.
    #203
    hehehe...onga eh, pansin ko rin, dun lang nag-iipon yung dust.
    #204
    i'm planning to try the wastegate mod but am lousy at diy, could any of you guys recommend a shop or mechanic that's familiar with turbo? :help!:
    Jan 2003
    #205
    PK, what do you mean by rotating every thousand or so kilometers? Parehas lang ang performance gains from drop-in filters and opentype filters?
    #206
    falken: any shop actually can do that. where ka ba? :D
    #207
    Quote Originally Posted by nugundam93
    sa sta. cruz area, but anywhere in metro manila puwede ako pumunta.
    Jan 2003
    #208
    where could I find the thai variable vane turbo specs? I couldnt find it in google. :D
    #209
    jedd, the Variable Geometry turbo produces 14hp (more or less) in the same 4D56TDIC. Not sure lang what other components they changed.
    I meant iiikot yung filter because if not, only one side of the filter will get ditry. and over time this will deteriorate the filter oil and allow dirt to come in.
    Jan 2003
    #210
    ah!! now i get it! hehe so dagdag maintenance talaga. :D
    diba our stock turbos produce 12 psi? 4d56 engines can only handle up to ilang psi?
Cranking up the boost on the 4D56TDIC
