Results 1 to 10 of 14
- Oct 2010
- 3
November 3rd, 2010 08:40 PM #1I hope somebody can help me in my problem.... nung nasa nlex ako gamit ko po yung adventure ko na model 2002 ay ayaw tumakbo ng mahigit sa 110 km/h... tpos po ung rpm ko po sa 4th and 5th gear hindi po lumalagpas sa 3000 rpm... kahit todo na po ung apak ko sa gas.... from balintawak exit hanggang dau exit ganun lng po ang takbo ko po... sna po may makapag suggest sa kin kung ano po dapat gawin ko po...
November 3rd, 2010 08:44 PM #3
That's unusual.
Normal top speed of the Advie is around 130kph.
Might need some tune up.
November 3rd, 2010 08:47 PM #5
November 3rd, 2010 09:04 PM #6
marami dito bro, 110kph max naka speed limiter, usually mga company cars...
dati ride ko, max 170kph lang....naka speed limiter din,pero personal ko yun...
maaari sa engine o sa tranny nya problema....di nya kasi sinabi specs ng auto nya... di ba dapat ganun, sabihin lahat para di mahirap magadvice?
November 4th, 2010 09:45 AM #8
Me too!!! 2002 Adventure, diesel, can't pass 80kph at NLEX. Hirap mag-overtake din. Mahina yung hatak.
Check your timing belt Sir, had ours replaced and then OK na ulet.
November 4th, 2010 09:57 AM #9
gas or diesel? some possible causes:
1. restricted air filter
2. worn out clutch
3. improperly tuned / not tuned or incorrect timing
4. blown engine
November 5th, 2010 01:46 AM #10
bro ngyari sakin yan...b22 sakin.....minsan madumi lang fuel filter at at air filter....pachek mo muna yun...saka oil change.kapag wala p rin baka masworse....hopefully hindi...
Thank you!
