Results 11 to 11 of 11
- Jun 2008
- 1,741
July 18th, 2012 08:59 PM #11Wag ka agad maniwala ng general overhaul ek ek na yan. Dalhin mo sa shop na may compression tester. Pasukat mo ang compression pressure, kung mababa talaga then saka ka mag decide na mag pa overhaul ng piston/rings & intake/exhaust valve lapping. Pa calibrate mo ang fuel injectors (sabi mo fuel injection pump lang) baka yan lang ang problema. Pag katapos ba ng fuel pump calibration ay tama ang pagka balik ng injection timing? Pa check mo ang timing sa talagang marunong, better check your manual for the correct ignition angle (degrees BTDC). Yan muna ang pagawa mo then see kung mag improve. HTH
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
