Results 11 to 20 of 20
- Feb 2010
- 6
February 20th, 2010 09:23 PM #11cleaning nga lang po yan... kc 20k pa lang tinatakbo ng car nyo... sa akin umabot ako ng 150k bago nagpalit ng e.valve at drier...
- Mar 2010
- 13
March 17th, 2010 12:22 PM #12Hi,
I have studied a little bit of aircon myself. Based on my studies. It is true that you need to maintain the aircon properly. CASA is usually more expensive as always. But the real price of the Receiver Dryer and Expansion valve should be below 2K pesos each. These two items are commonly replaced. If the car aircon is maintained properly then it is rare to find anything wrong with your Evaporator, compressor and condenser.
CHEERS
- Jun 2014
- 1
June 25th, 2014 05:11 PM #13mga sir's, ask ko lang kasi nawala yung lamig ng aircon ng adventure nmin 84000 km n (2010 model GLS sport) nalilinis naman po sya at napapalitang ng mga filter, san po ba makakamura kasi mahal sa diamond motors at ano po ba masusugest nyu unang car ko po ito! tnx more power
- Apr 2007
- 487
June 25th, 2014 05:18 PM #14Sa age ng adventure nyo, pwedeng palitin na nga yung drier and expansion valve. Ang use kasi ng drier is absorb the moisture inside the cooling system para mas malamig yung buga ng AC. Pwede mo naman pagawa sa iba. PInapalinis ko AC ng adventure namin every year, around P2.2k ang damage. Last year, hindi na sya lumalamig kahit bagong linis at bagong refill ng freon. Nung pinalitan yung drier at expansion valve, good as new na ulit. Total damage that time was around P6.5k.
June 25th, 2014 05:32 PM #15
- Apr 2009
- 7
November 27th, 2015 03:07 AM #16Metikuloso si Sir Joel. Kelangan masatisfy nya yung customer nya bago umalis ng shop nya.
And the a/c service crew ng Ceejay's, mababait
2 thumbs up ako sa Ceejay's!
- May 2018
- 1
June 15th, 2018 09:46 PM #17Good pa rin ba service ni Ceejays just asking before going... if ever na may nicer service provider as A/C Adventure na endorse nyo mga Sir pakibanggit na lang din Thanks in advance.
- Jun 2018
- 1
June 26th, 2018 03:52 PM #18Im sorry Sir BobbyDBilder, hindi pa po ako marunong mag-open ng new thread, nag reply with quote ako.
Mga bossing, inquire ko lang kung ano gagawin pag pumapasok ung amoy sa labas thru the aircon sa Mitsu Adventure kahit nakasara ung air intake switch? Talaga po bang walang cabin filter ang Adventure? Pag wala pong cabin filter, paano po gagawin? Kahit po kasi bagong linis ang aircon, pumapasok pa din ang amoy ng tambucho ng nasa harapan ko na sasakyan, o pag me nadaanan ko siga, amoy ang usok sa loob ng sasakyan.
Thanks po ng marami.
June 26th, 2018 05:01 PM #19
Same problem with our CR-V 98. I had them blocked entirely the airway. Then, this Aircon guy suggested that he will assemble an air filter, a metal frame where I can use stockings.
I think old models doesn't have this cabin filter or only the super duper luxury old cars only.
June 27th, 2018 06:56 AM #20
I had the exact same problem w/ my civic ek a few years back. The solution of the a/c techs of ceejay's a/c shop was to cover the vent w/ a wad of new foam w/c allows outside air to enter the vehicle when the recirculate button is deactivated.
Apparently hindi equipped ng cabin filter feature iyong mga old ek models kaya kapag nadurog iyong original foam covering ng vent over time, wala ng nag fifilter ng air na drawn from the car's exterior.
Wala ba talagang feature na cabin filter ang mga adventure? Medyo late model release nanaman mga iyan ah
do what you gotta do so you can do what you wanna doLast edited by baludoy; June 27th, 2018 at 07:08 AM.
thank you its good naka timing chain pala. yan din concerns ko sa used car like sa dati kong...
