Results 1 to 10 of 19
Tsikot Member Rank 3
- Apr 2004
- 663
December 19th, 2004 03:26 PM #1Hi. I'd like to solicit your comments on this setup. It is supposed to add in air into the engine to improve exhaust (in terms of the smell coming out of the exhaust) and maybe add a little power (?)...
- Apr 2004
- 663
December 20th, 2004 11:33 AM #3not sure how to categorize... I'd like to solicit comments especially from those more experienced/knowledgeable in diesel engines before I try this myself...
December 20th, 2004 12:23 PM #4
ano yan parang intercooler?? hehehehehe
anyway if you can get cooler air into the engine yup there will be improved performance pero dun sa setup na ipinakita mo, anong klaseng cooling fan ang ginamit???
December 20th, 2004 01:48 PM #5
looks like the turbo-zet thingie... wherein they placed a "cooling fan" (the size of it is similar to the cooling fan of your computer.
for one, it can actually cause partial blockage of air into your engine at high rpm. at idle it might help but are there test results to verify this claim?
December 20th, 2004 02:01 PM #6
parang turbo a. ok, let's just call it a 'forced induction', it's not necessary a turbo but the air is induced to the air intake. may effect ba sa power? pakiwari ko, di kasing effective ng turbo yan pero may tulong na din kahit paano. i wonder how it behaves at high-rpm's.
- Apr 2004
- 663
December 20th, 2004 02:04 PM #7i guess it's not really meant to give any power boost... the person who shared this mod wasn't really after extra boost... he was concerned more about the exhaust... his wife complained about the smell of the exhaust of diesel... supposedly with this modification, the 4d56 engine's exhaust doesn't emit the usual bad odor...
December 20th, 2004 02:06 PM #8
i looked it up sa web and it costs roughly 6K to 16K depende sa brand. 'induced air intake ' is what it's called. if i have the money i won't buy this. tests show only 6% increase in power (kung totoo ha) pero that measly increase i would just buy a better cold air intake tube and filter.
December 20th, 2004 02:12 PM #9
aha. alam ko na! oo nga, para di masyado mausok! :D kasi napansin ko sa diesels kapag binibigla ang tapak sa accelerator pedal, dun umuusok. bakit? kasi hindi masyado nasusunod ang krudo. whereas, if there is sufficient amount of air in the air/fuel mixture, mape-prevent itong pag usok na ito. :D
- Apr 2004
- 663
December 20th, 2004 02:19 PM #10Originally Posted by jimLast edited by RafRaf; December 20th, 2004 at 02:22 PM.
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
