Results 11 to 20 of 31
October 14th, 2002 06:14 PM #11
:shock: P4.6M :shock: Napakamahal pala nun! Totoo yun! pati nga kotse dinadala nila sa disyerto para mag off roading, mahilig sila sa ganun pati sa burnout.
800 HP! malamang di dito sa Saudi yung tweaked LC100 na yan. Bawal daw kasi mag karga ng makina dito (bawal pero nagkalat din naman ang mga V8 at V10 engines :lol: )
Isa lang ang di ko makakalimutan na na drive ko dito... yung GMC Sierra na dually!!! Syet! ang sarap manehuhin, ang laki pa, di ko yun pagpapalit sa HUMMER. V10 engine na A/T pero lakas humatak. Haayyyy!!! Sana magka ganun ako sa pinas! :D
- 342
October 14th, 2002 09:38 PM #12kimpoy,
na experience m n rin b sa strada ang black smoke? siguro proper aintenance lang every 5t check up. compare m sa hi lux di naman siguro ganon ka grabe d b?sana 2.8 tuber intercooler sa strada mas ok p mas di mausok yon di b?
attemtion : otep kcboy what can u say about this?
February 20th, 2007 02:07 AM #13
try nyo po magpakalibreyt ng sasakyan kasi lahat basta diesel kailangan ikalibreyt kapg mausok na itim ibig sabihin sa injenction pump un..kapag puti makina na po un...
February 22nd, 2007 09:20 PM #14
Sir, magkano naman po gagastusin kapag nagpa calibrate/engine overhaul or diagnose ng 4d56 engine? i also encounter thick black smoke and hard starting even if the engine is still hot, some shop says it due to its compression daw kaya di mag start agad
February 22nd, 2007 09:41 PM #15
kahit anong makina diesel or gas basta balasubas ang driver at walang TLC sa makina uusok.
February 22nd, 2007 10:18 PM #16
- Mar 2006
- 10
February 23rd, 2007 09:39 PM #17hi when do you decide to have your engine recalibrated? i have a mitsu adventure 99 model mag 82t km na, but so far ok parin ang performance ng engine ko, only a little mausok.
- Jul 2005
- 95
February 23rd, 2007 09:45 PM #184D56 is a very dependable and durable engine, even till now, the 2007 Strada is still equipped with one (common rail version). Just make sure the unit's in good condition, change the air filter, hose out the muffler, change the engine oil and take her out for a spin on the North Expressway. Once all the carbon's been removed, you'll find that there's less smoke. Good luck!
February 26th, 2007 12:26 AM #19
March 7th, 2007 05:20 AM #20
4d56 is a very reliable engine. bit slow but easy to maintain. i had L300, then currently using adventure. i just like this engine, quick start and spare parts are always available. yup, mausok talaga ang 4d56 pag kulang sa alaga. regular change oil lang, sabay palit ng air filter, then i had mine tune- up every 6 months. alalay lang sa arangkada para di masyado mausok. proper timing sa pagmaneho.
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
