Results 11 to 20 of 22
- Jun 2007
- 8
October 1st, 2007 06:22 PM #11Mga sir tanong lang po ako-is there way to minimize black smoke coming out from tambutso ng ADV-02(4D56-diesel)..pag start kasi laging meron black smoke esp sa umaga then as you travel it becomes lesser..gumamit na ako K1R, meron na din ako Fuel Enhancer (similar with vortex) ganun pa din...balak ko na pa-overhaul yong injection pump pero gusto ko muna makasiguro kung yun nga ang tama gawin. Hindi daw naman blow bye yung engine kasi hindi pa daw naman kumakain ng langis at hindi naman white smoke ang lumalabas..I went to one shop sa Alabang dahil dun daw may gumagawa ng injection pump,(i cant recall yung pangalan nung shop), aabutin nga 16K pag pina-overhaul ko. Is it really advisable or worth na ipagawa ko na injection pump ko, pinakabitan ko na din last week ng drain valve sa ilalim, para madali lagyan ng H2O hose pag linisin ko yung muffler.Looking forward po sa mga advises nyo...
Sensya na po at medyo mahaba kwento ko..Thanks in advance!
October 2nd, 2007 04:20 AM #12
*ABM: normal lang po yan sa engine na may edad na. just have a basic nozzle pressure check and cleaning. puwede rin mag pa compression test ka nalang muna.
- Jun 2007
- 8
October 3rd, 2007 05:22 AM #14
your welcome, you can also have a Injection pump general cleaning nalang.
or Carbon clean
more info here:
http://tsikot.yehey.com/forums/showt...ighlight=sarap
- Apr 2007
- 11
March 10th, 2008 08:35 PM #15Sir good day! may ask lng po ako sa inyo lahat, about my L200 model 1995 gusto sana mangyari sa engine ko sana iminimize yung ingay niya tapos may nag suggest sa akin na palitan yung injection pump ng injection pump ng hyundai but my injection pump it is ok. anu sa tingin ninyo pwede ba? ang orignal ng injection pump ng L200 pa square dba yung ipapalit parng circle yung shape.....
- Apr 2007
- 11
March 10th, 2008 08:38 PM #16sir good day again! ako ko lng pwede ba lagyan ng turbo charger yung 4d56
March 12th, 2008 08:32 AM #17
afaik, different internals yung n/a 4d56 vs turbo 4d56.
though one tsikoteer here says he was able to add turbo in his n/a 4d56.
- Nov 2004
- 141
March 14th, 2008 07:24 AM #18the pistons and piston rings need to be replaced with turbo type. a surplus turbo charger costs 10-12k and you need to have it overhauled (at a cost of another 10K). you'll need to buy a turbo type intake manifold at 5-7k.
Bili ka na lang ng surplus na 4D56TID, saka mo landiin para sigurado ka pa. you can always sell your NA 4D56.
- 5
March 15th, 2008 02:51 PM #19im new here at tsikot. tanong ko lang if may available bang gasoline engine that will fit my 99 model L200 na may 4d56 diesel engine. thanks!!!
- Apr 2008
- 1
April 8th, 2008 10:26 PM #20magpapalit sana ako ng diesel engine para dito sa L300 VV model '97 ko, ang makina ay 4G63A, mag fit kaya ito dyan sa L200 mo? Mga brod baka may idea kayo . . . .
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
