Results 21 to 30 of 31
Tsikot Member Rank 3
- Aug 2003
- 1,251
October 10th, 2016 10:41 AM #21I have sent in the unit to the casa this morning. We will have it top overhauled. Main suspect is the gasket. Di naman nagbabawas ang radiator kasi if ever umakyat ang temp, I quickly do something to bring it back down within that minute.
October 10th, 2016 10:58 AM #22
iba na andar kung putol yung balancer belt. hindi balansyado ang takbo kung ganun......
pero worth a try din siguro. kung magpoprocede ka ts sa cylinder head servicing e isabay mo na timing belt.
btw, 22 psi is i think way over the limit....baka yan pa magcreate ng panibagong leak.
e kamo 15 psi lang yung radiator cap. do not go beyond that when testing.
- Aug 2003
- 1,251
December 3rd, 2016 05:07 PM #23Just to update. Replaced the cylinder head gasket and the valve seals. A little head refacing. Before this was done, we opened the radiator cap after uminit na to operating temp ang makina, there were an ever so slight fine bubbles that can be seen but if under sunlight, then an occasional large bubble, a sign of a little leak from the gasket. So far, the unit is running for 2 weeks, no overheat.
- Dec 2016
- 2
December 7th, 2016 12:04 PM #24mine naman ung cylinder gasket nasira.san b ko makakabili nun near caloocan camarin area?
Sent from my SM-E500H using Tsikot Forums mobile app
- Dec 2016
- 2
December 7th, 2016 01:19 PM #25Pg nasira ung cylinder block ng 4d56,narerepair p b un?
- Oct 2008
- 64
December 20th, 2017 10:52 AM #26Im experiencing temp creeping pag paakyat or at heavy load. Meron ba kayong nakakaalam ng pwede magpreassure test for leak. Feeling ko kasi baka radiator clogged.
December 20th, 2017 02:46 PM #27
after your first coolant replacement(48mo) ang succeeding replacement is 24mo?
- Jul 2016
- 237
December 21st, 2017 12:35 AM #28
- Sep 2017
- 177
December 21st, 2017 03:44 AM #29What I did in my vehicles pag ganun temp issue is that I switch to a bigger radiator and add another fan. That happened to my old starex the stock rad couldn't take the uphill trips so I just got a bigger rad and added another rad fan.
- Oct 2008
- 64
December 22nd, 2017 08:32 AM #30I had it replaced 48months then when i experienced the creep nag change ako ulit. No leak sa radiator, cap at water pump replaced. No milky oil nor oil coolant sa radiator. Possible culprit ko nalang the radiator or a blown head gasket.
chinchilla fur vest leatherjacketback
Verifpro - paypal, ebay, banks, crypto, docs and...
