Page 11 of 13 FirstFirst ... 78910111213 LastLast
Results 101 to 110 of 127
    Feb 2011
    #101
    Quote Originally Posted by ron_kimi View Post
    Hi I have a 2014 glx with 28T Kms on it. I just experienced that while running 100 kmh up i feel a strong vibration on the steering wheel when braking. But when i dont not apply on the brakes there is no vibration. Any tips on what could be the cause? I suspect it could be a warp rotor disc or worn out tie rod.
    Yup, this is a common issue for this model. It's the rotor disc if I remember correctly. Not dangerous (according to a specialist i consulted) but definitely irritating. hehe.
    You can opt to replace it but expect it to be back after some time.
    #102
    Warped rotor is likely.
    Jun 2010
    #103
    Quote Originally Posted by pobre24 View Post
    Thanks for the info sir can refacing the rotors solve the problem or do i have to replace them?
    #104
    The tok sound in the collapsible steering of my Mits Adventure was addressed by installing a hose clamp. 10 years had passed, never occured again.
    May 2008
    #105
    Quote Originally Posted by b0y37 View Post
    Sir, anong part ang sinecure niyo with hose clamp? Thanks
    #106
    Quote Originally Posted by blacksilver323 View Post
    Doon sa collapsible steering column. If I remember right, nababalutan ng plastic material yung steering column, eto yung "collapsible". Lagyan mo lang ng clamp para humigpit. Ill try to take a pic pag may time.
    Parang ganito yata sya, lagyan mo lang ng mas malaking clamp:
    Redirect Notice
    Jun 2011
    #107
    Hi guys. Naexperience ko na din tong knocking sound sa steering column lalo na pag uneven road. May i ask magkano na spend nyo parepair nito sa mitsu casa. Plano ko sanang paayos kasi nkakairita na. Thanks
    Redirect Notice[/QUOTE]
    Sep 2018
    #108
    Quote Originally Posted by ydrion View Post
    Redirect Notice
    [/QUOTE]
    May nakaranas ba ng ganitong issue sa 2018 model?
    Jan 2019
    #109
    Hello sirs! I had a 2012 Ford Fiesta with electric power steering that developed a severe steering rattle over uneven road. Ford was never able to fix it. Then I had a 2013 Kia Rio sedan also with EPS. KIA Ormoc changed the flimsy plastic rack bush inside the electric power steering column twice. Good only for a few months and the steering rattle came back. They also changed the steering electric motor, rattle still there. I sold the car after 5 years.
    Now i have the 2017 Montero Sport with about 16k kms on the odo. I feel a very slight rattle on the steering over uneven road at low speed. Mitsubishi Ormoc said its normal to have a slight rattle. Driving at high speed on highways, not a single rattle can felt; Steering is very smooth. EXCEPT it veers slightly to the right! As i read over the posts here, I realized this is not an isolated case and is a very common issue to this new Montero. I will have my Monty checked at the Mitsu shop tomorrow. I just hope this is covered by their warranty because as per inquiry, they said steering alignment would cost around P2,000. And I also hope they will resolve the issue.
    #110
    Feeling ko, this would fix ur problem.
    Basta EPS steering mo.
    Labor charges will be quite high, dissasembly is hard.
    Of course, find one that fits ur brand na car
2016 Montero Sport Steering Issue
