Results 7,511 to 7,520 of 7539
August 18th, 2020 03:33 PM #7511
Probably a leak, they said that there is an increase of gen3 cases, mostly due to damaged condenser tubes because they said they were thin. Probably caused by vibrations.
And there they add "pressure or temperature build up" due to the lack of AUX fan
*doc
There's a few around 3.5k-4k. Forgot the brand, yellow-greenish box.Last edited by ronki; August 18th, 2020 at 03:35 PM.
- Jul 2009
- 2,618
August 18th, 2020 04:34 PM #7512swertihan bro. our gen.2 aux fan lasted only 2yrs. pinalitan ko yung motor ng circuit kasi yin lang available 900pesos ata. if i remember tapos di ako mapakali replaced it with an orig mitsubishi made in japan. 2300pesos. conversely may kaibigan ako gen2 had his original aux fan last 5yrs. so ayun go figure.
- Jul 2009
- 2,618
August 18th, 2020 04:40 PM #7513as i know latest gen. ng montero and fortuner only has the single clutch fan from segunyal. no electric aux fan. i don't know how they make the aircon work that way.
gen.2 montero has a single electric auxiliary fan for the condenser. i think our 2015 fortuner also does not have an electric aux. fan.
- Jul 2009
- 2,618
- Jan 2008
- 4,726
August 18th, 2020 05:53 PM #7515
- Jan 2017
- 81
August 22nd, 2020 01:26 AM #7516May mga nakaexperience na ba sa inyo nito? 2017 GLX Manual model ko.
1. Grinding feeling sa clutch when switching gears. Intermittent siya at pansin especially during low speeds (1st gear-3rd gear).
Mahirap i-shift minsan ramdam ko shifting cable na parang hindi lahat ng threads niya kumakapit.
2. Minsan may ramdam mo na nagvvibrate yung gas pedal. Nawawala naman. Intermittent din, madalas wala pero minsan meron.
3. Naglolockout yung gear during shifting. Naexperience ko minsan, di ko mashift sa 4th gear parang barado. Ginagawa ko, balik neutral ulit tapos shift ulit. Nakakatakot lang kasi high speed ka tapos biglang babara.
Pashare naman kung may nakapagpagawa na (at kung saan) or nakaexperience na sa inyo. Salamat.
- Feb 2010
- 336
August 22nd, 2020 10:22 PM #7517
share ko lang guys, mine is monty glx m/t 2017
just last month ngpa-pms ako kay sir zix ng 40k instead sa casa anyway expired na pms+ warranty ni teros
one of the things na nasabi and pinakita ni zix are the parts lacking na dapat nakalagay sa monty like rear damper at front aux fan na may abang na
cost me 1k for damper and 6k for aux fan plug & play, somehow bumilis naman lumamig specially when super hot at noon, big help naman
- Jul 2009
- 2,618
August 22nd, 2020 10:56 PM #7518
August 22nd, 2020 11:02 PM #7519
August 25th, 2020 12:36 PM #7520
A tiny update for mid-life update. Its going to be a long wait for the "wide" next gen.
Daming issue ng SU7:grin:
Xiaomi E-Car
