Results 3,931 to 3,939 of 3939
June 25th, 2019 04:32 PM #3931
- Jan 2015
- 15
June 25th, 2019 04:35 PM #3932Thanks po... akala ko kasi parallel sya icoconnect... pero di ko muna tinuloy...
June 25th, 2019 04:42 PM #3933
Connecting it in parallel with the LED bulb will effectively lower the R - even lower than the current LED bulb resistance.
Bro - you need to increase the resistance as seen by the circuit and the capacitor,- and so you place it in series with the LED bulb/light. Just cut the wire just before the socket and connect it; Works on either of the [2] lines
Have not really tried it,- just theory based on this...
T=RxC...
- Nov 2013
- 17
September 29th, 2019 06:09 PM #3934
- Jul 2006
- 6
October 8th, 2019 10:17 PM #3935
- Mar 2018
- 263
November 12th, 2019 10:49 PM #3936Make sure that the aux cable you are using is AV. Try this. TV Plus to Car Monitor AUX Socket Direct Cable GZ-8 5 3.5mm AV Baby to Baby Plug 1.5meters | Lazada PH
Sent from my SM-G975F using Tapatalk
- Jan 2024
- 1
January 22nd, 2024 11:31 PM #3937I have an question/issue with my 2013 montero. Specifically the power side mirrors… when I activate my power side mirrors the passenger’s side mirror folds open to its correct position while my driver’s side mirror folds open too much, it folds open to about 180 degrees but when I press the button to fold the side mirrors back in, both side mirrors fold in just fine only when they fold out the driver’s side folds out to 180 degrees while the passenger side mirror folds out just fine. Is there a way synchronized the side mirrors without having to open up the driver side mirror? Thank you.
- May 2008
- 137
January 23rd, 2024 12:01 PM #3938Hi Incy, nabali na yung stopper niyan kaya open wide na siya. Dati, nangyari na sa Montero namin yan. Pansamantala, hinahawakan lang namin kapag nag-open para tumigil sa desired angle hanggang pinalitan na rin namin ng replacement side mirror. We asked casa about repair, palit buo rin ang suggestion kaya naghanap na lang ng cheaper alternative online
Sent from my Xcover Pro using Tsikot Forums mobile app
- 52,698
January 23rd, 2024 12:32 PM #3939
It's looking like Shopee / Lazada / AliExpress have a long list of available parts for various...
2024 Manila International Auto Show APRIL 4-7,...
