Results 5,481 to 5,490 of 5834
- Feb 2014
- 7
June 20th, 2014 11:59 PM #5481
June 21st, 2014 02:41 AM #5482
June 21st, 2014 09:44 AM #5483
- 29
June 24th, 2014 10:52 PM #5486
- 29
June 26th, 2014 08:21 PM #5488
Nitro+ uses higher-quality base fuel (which also has higher RON). However, as previously mentioned, higher RON itself is not beneficial for ordinary cars.
The other difference of Nitro+ from FuelSave (and same with XCS from Xtra) are the additives used. Usually, premium gasoline has more detergents that help keep your engine lubricated and clean.
Of course, the actual effect of this on your driving varies per car and driver. So it's best to try and compare full tanks of regular and premium gasoline.
Posted via Tsikot Mobile App
- 29
June 26th, 2014 08:27 PM #5489hey..thanks..i will definitely try and see if there is a noticeable difference when using fuelsave
June 26th, 2014 09:33 PM #5490
Our Mirage uses Fuelsave most the time. Sometime when I feel generous I fill it up with Nitro+ or Caltex Gold to clean the fuel system.
Noise barrage daw against MVIS: VOLUNTEERS Against Crime and Corruption... - CAMPI Clean Air...
[AI] Here's what they'll check during MVIS...
