Page 397 of 585 FirstFirst ... 297347387393394395396397398399400401407447497 ... LastLast
Results 3,961 to 3,970 of 5843
    #3961
    Hi mga mirage owner particularly for GLS-CVT... na eencounter nyo ba problem sa braking...as posted by the others, I have no comparison previously because I have not owned a brand new car, what we had is an old lancer that was not brand new wherein the brake is very deep....
    any comments on the Braking issue for some?
    Oct 2009
    #3962
    ^as far as im concerned its the driver who possess the INTELLIGENCE to adjust to a cars behaviour, its not the other way around
    after all not all cars are created equal
    Well said. Actually, when driving a car na hindi mo pa na-handle before, it's necessary to check first how the brake, gas and clutch (if MT) respond sa apak (pati na din yung pagtimpla ng gas and clutch).
    Dec 2009
    #3963
    ^there is a reason why the driver seat is adjustable, stepping on the break & the clutch at the drivers comfort is one of them
    FULL STOP requires the driver to step on the clutch & break pedals deep
    on the other hand DECELERATION would require the driver to still press on the break pedal hard enough for the break pads to touch discs
    nudging the break pedal will simply not cause the car to DECELERATE (maybe for automatic tranny) much more proceed into a FULL STOP (not even for automatic tranny)
    Aug 2012
    #3964
    Quote Originally Posted by Spark1.2MT_Bj View Post
    salamat sa input nyo sir, medyo nabawasan yung lungkot ko sa glx, hehehe. gusto ko kasi sana gls ang dami kc features na wala sa glx na meron sa gls 90k lang ang difference. sayang talaga..
    anyway sir, magkano po pala yung gastos central lock+alarm at saang dealer nyo po pina-install. gaano rin po katagal ginawa? TIA
    It cost us 7k flat po to have it installed sa citimotors LP, and it took 7hrs para matapos yun kasi nagkabit sila nang motor for the central locking and alot of wires for the alarm system. =).
    ako po dati i was planning to get a gls because of its feature pero napag isip isip ko na for an everyday car na gagamitin pamasok at madaling malalaspag, i just need a simple vehicle that can take me from point a to b. kaya in the end glx ang binili namin. =).. depende po talga yan sa pagagamitan mo ng sasakyan mo.
    In addition po, as said sa newer posts, pati ako po nahihinaan sa brake nang glx mirage (no abs+ebd) vs. our toyota (w/ abs).. pero natatandaan ko based kasi sa handouts nila dati, pinpapakita sa sa illustration na tlga mas malayo ang breaking distance nang walang abs+ebd sa may abs, at may ebd.. baka kaya po ganon.. im not that sure din kasi i havent driven a gls yet.hehe =)..
    #3965
    Hi mga ka mirage meron ba sa inyo living in Manila and working in Pasig....and you are planning to use your mirage from house to work area and vice versa....how is the mirage experience in passing from Makati ---> EDSA --->Pasig and back and forth?
    thanks
    Sep 2008
    #3966
    Quote Originally Posted by glennba View Post
    agree din ako dito sir nasa driver lang talaga,same thing sa unit ko day 1 talagang hirap ako sa clutch mataas sya. the following day eto na maski pataas pa yan o pababa walang problema.
    Nov 2012
    #3967
    Hi Mirage GLS M/T owners jan. Kanina nagddrive ako papuntang burgerking sa marcos highway habang nagddrive ako biglang tumunog ung mirage ng prang madaming beep sounds ano po ba ibig sabhn non? tas mya mya nwala na ung sounds nya prang paminsan minsan tumutunog sya. pero d na ulit naulit nung pauwi na ko TIA
    Nov 2012
    #3968
    Question po regarding sa Refund ng Mirage... May duration po kaya ang refund?
    Kasi sabe sakin 3weeks pero wala pa rin. Baka kasi masayang ang 10k PHP ko eh. May duration po ba ang Refund ng Reservation ng Mirage? kasi baka mamaya tumagal po ng tumagal at yun pala wala naman balak ibalik. (di ko po kasi masabi kung anu balak ng Dealer o ng SA) . Tsaka nakakatakot mamaya mag set sila ng date tapos may Duration lang pala ang pag Refund tapos pag kukunin ko na bigla sabihin na lagpas na ko sa given time..
    ( di naman pinupulot ang pera).. gusto ko lang po kasi maclarify e. nakakatakot masayang ang pinaghirapan..
    TIA
    Apr 2012
    #3969
    Quote Originally Posted by aesir1103 View Post
    Baka hindi kayo nag seatbelt sir?
    Sent from my Galaxy S using Tapatalk
    #3970
    Hi mga ka mirage....kamusta po ang mga naexperience ng PMS for 1000Km for a GLS-CVT? meron na po ba naka experience sa CITIMOTORS Makati at ano po ang masasabi nyo at magkano ang naging Cost?
    thanks
    - - - Updated - - -
    thanks
2013 Mitsubishi Mirage
