Page 364 of 585 FirstFirst ... 264314354360361362363364365366367368374414464 ... LastLast
Results 3,631 to 3,640 of 5843
    Dec 2012
    #3631
    Quote Originally Posted by egaieskie03 View Post
    sir habaan mo lang ang pasensya mo sa haba ng pila, meron pa nga dyan october pa hanggang ngayon wala pa, pero kung hindi ka mapili sa kulay na gusto mo e malamang iyan maunahan mo pa sila...good luck sir.
    oo nga po. I had mine reserved last October - GLS M/T. Till now wala pa din.
    Mar 2012
    #3632
    Quote Originally Posted by darkpanday View Post
    May additonal na upgrade ka pa na kailangan kunin - Tire Pressure Monitoring System (TPMS). Nung nag tanong ako sa SA na kausap ko, it's worth PHP 17K for all 4 tires.
    Is TPMS worth buying for 17K? I don't think so but well kung di problema pera pede ren.
    Aug 2012
    #3633
    Quote Originally Posted by *sludge* View Post
    sir maitanong ko lang po, dealer's discretion po ba ang EWD o standard po na kasali yun sa GLS na variant?
    standard freebies na po ngayon yan sa lahat ng dealer.
    Apr 2012
    #3634
    Maranong lang mga sir/mam, yung instrument guages, d rin ba lit yung inyo at start up? On lang kasi yung akin if on ko dim or headlights. Ok naman if on a bright day, pero tulad kanina n lakas ulan, medyo madilim, d ko makita. Is there a way n always lit yung instruments?
    Dec 2004
    #3635
    Ganun talaga, unless you have Optitron gauges or something similar. If it's raining hard, you should have your low beams on anyway.
    #3636
    Quote Originally Posted by nrthstr View Post
    Afaik ours are not optitron gauges sir..youll need to turn on the park lights to light it up ;)
    Jan 2008
    #3637
    Has anyone noted that there is no covering for Rear Plate number lighting, leaving a huge nasty opening exposing the electrical wires/bulbs and where dirt, dust, mud, and water can easily enter. What mods can you suggest for this.
    Apr 2012
    #3638
    Quote Originally Posted by Alpha_One View Post
    naman o..... anyways THANKS SIR!
    #3639
    Quote Originally Posted by noob*cars View Post
    Mga sirs, sa user's manual, may nakasulat na meron daw cabin/aircon filter yung mga mirage natin. Saan po ba siya makikita? In case lang na gusto ko linisin yung aircon filter... TIA!
    its located behind the glove compartment..then remove the black plastic cover..youll see the aircon filter ;)
    Nov 2012
    #3640
    Quote Originally Posted by a329 View Post
    Nice FC nga po, nagulat nga rin ako e.hehe. Depende po kay kumander pero normally during AM nasa number 2 ung fan then nasa around 3/4 yung lever sa thermostat control. then sa PM number 1 nlng then the thermostat lever is adjusted 1 to 2 clicks to the left.
    Sir elibs ako sa FC mo and the way you drive astig nasa humahawak talaga ang FC.. Bago lang po ako magdrive eh, hingi po sana ako tips and advice eh. Mejo nalalaliman ako sa clutch( unlike the strada l200 na dinadrive ko di nako namamatayan ng makina esp pag paahon though naka set up ng mejo mataas) kasi mejo or lage namamatayan makina pagpaahon or hinto tapos abante sa mirage, hingi po sana ako sa inyo mga pro and experienced ng tips..(sana makuha ko yung tamang way pag apak sa clutch and accelerator)..
    Maraming marami pong salamat sa inyo..
    More power mirage~
2013 Mitsubishi Mirage
