Page 323 of 585 FirstFirst ... 223273313319320321322323324325326327333373423 ... LastLast
Results 3,221 to 3,230 of 5843
    #3221
    Quote Originally Posted by caloyphil View Post
    Maganda niyan , yun ginawa ng Honda city /jazz challenge , Full tank yun mga mirage tapos pataasan ng kilometers na makukuha hangang maubos yun last drop ng full tank .pinaka mataas na tinakbo yun may premyo ! Malalaman na natin actual FC sa real world sa Pinas.
    Magandang challenge eto para sa mitsu ............patunayan ninyo !!
    To make it technical and scientific and to cancel as much variable as temperature, speed, road inclination, driving style, traffic, city drives, highway drive, etc, a procedure was made to standardize how fuel consumption is measured.
    Kung baga, ito ang ruler ng fuel consumption, analogous sa ruler na pang sukat ng haba ng pang wiwi mo
    Mas madali kasing sabihin na "6 inches" ka kaysa "isang dangkal" ka.
    Eh paano kung dangkal pala ni Mura
    May iba-iba pa ring style ng FC calculation depende sa part of the world pero let's talk about EU Combined Cycle.
    Ito ang procedure na controlled ng UNECE World Forum: New European Driving Cycle - Wikipedia, the free encyclopedia
    Using the same EU combined cycle test, ito ang rating ng dalawang kotseng napupusuan ko:
    Honda Jazz A/T: 14.92 Km/L (via Honda Jazz Review | CarAdvice)
    Mitsubishi Mirage: 21 Km/L (via Mitsu brochure)
    So using the same ruler, the Mirage is better.
    So if you bring it home and do your usual driving route, you will consume less gas with a Mirage.
    #3222
    Quote Originally Posted by dct View Post
    that's a good idea. mas maganda sana pag may ibang subcompact na car. para mas ma-compare
    sa kia picanto ko ngayon (2005) mga 10kml avg, daily route is from bonifacio to UP technohub (about 20km distance one way trip)
    Jun 2012
    #3223
    Quote Originally Posted by saintbodhisatva View Post
    whereas the mirage is averaging what? with the same route
    #3224
    ganito yan:
    if a car moves forward, all front wheels and the steering wheel will go back to center front. kusang didiretso 'yan.
    if the car does not move, then the front wheels and the steering wheel will not budge from their current position. hindi gagalaw yan.
    Dec 2012
    #3225
    huong dan ca cuoc tren mang
    huong dan ca cuoc bong da
    huong dan ca do bong da online
    huong dan ca do bong da tren mang
    huong dan ca cuuoc bong da online
    huong dan ca cuoc bong da tren mang
    huong dan ca do bong da truc tuyen
    huong dan ca cuoc bong da truc tuyen
    huong da ca do qua mang
    huong dan ca cuoc qua mang
    cach mo tai khoan ca do online
    cach mo tai khoan ca cuoc online
    Dec 2010
    #3226
    Mga Tol,
    Sa 1000KM PM pala, labor lang free. Katatapos lang ni Kuya at gumastos sya ng P3,068.00 para sa 4 liters fully synthetic oil at oil filter. Every 5,000KM ang PMS nya. Compared sa Fiesta, totally walang gastos ang 1000KM PMS at every 10,000KM ang succeeding PMS.
    Balak nya umakyat na ng Baguio dahil natapos anf 1000K PMS ng walang problema. Abot hangga tenga ngiti nya sa kanyang "Margie" (anagram of Mirage hehehe)
    Dec 2010
    #3227
    Quote Originally Posted by chewycandy View Post
    False and misleading ang ad ng Mitsu. Not fair. Bakit tayong consumer ang lahat gagawa ng adjustment at magbibigay ng allowance? Kahit sa mga early press release 21km/l ang binabandera nila.
    Nung lumambot buhok ni Kris Aquino dahil sa shampoo at hindi lumambot buhok mo, does it mean false advertising?
    May alam ka ba na car brand na nagbandera ng FC based sa Edsa?
    All of us should understand the nature of these claims and take them with a grain of salt. The are not lying at all but merely performed the tests in a near perfect environment.
    This way you save yourself from a lot of bitterness and heart ache.
    Malay mo bukas patay na ko o kaya me cancer na pala. Wala nang epekto ang FC nun.
    Just enjoy your ride.
    Dec 2010
    #3228
    Quote Originally Posted by youngrider View Post
    As consumers kelangan din talaga nating gamiting ang ating isip, di lang yung praise na lang ng praise, bad yan.
    Sir Caloy, yung mga fuel test sa Mirage eh lahat naka set up for Euro 4 compliance at naka-target din for fuel economy which will give monetary and other grants both for Mits and the consumers like tax exemptions and lower car registration fees. Here in the Philippines Euro 2 lang po ang set-up ng Mirage. I am thinking that aside from pulling out economy-system-gadgets (like regenerative braking, auto stop n go, alternator management, etc) and fuel quality, there maybe changes also in ECU settings of PH Mirage which if modified can give us better fuel economy.
    Napansin ko rin that compare with some other cars the the ratio of Mirage engine rotation per rotation of tire is higher though those other cars produce lesser power and torque. Kung lakihan kaya natin yung overall circumference ng tires di kaya mas matipid ito without serious negative effects
    sa torque and acceleration. Sabagay, it needs a dyno para ma-analyze yung power band ng Mirage at different engine speeds and loads.
    If you increase the tire circumference, KM reading in the odometer will fall and thereby falsely report a higher FC. Any change in tire circumference should have a corresponding adjustment in the car's computer to get an accurate KM reading.
    Apr 2008
    #3229
    Meron positive ....................refundable yun deposit na 10k hahahahahah
    possible ba na i transfer sa ibang buyer, para ma avail naman ang 40k reservation promo?, 20k discount nalang kasi now. tapos bayaran nalang yung nag reserve ng 10k.
    Dec 2010
    #3230
    Quote Originally Posted by Deobulakenyo View Post
    Re:
    1. I read a post by niky saying that the lower the rpm in high gears the more fuel efficient it is.
    2. So Mirage GLX and a Mirage GLS, clamped together and driven around will not have the same odo readings since the GLS has a bigger wheel diameter, right?
    3. I guess it should be the opposite. The fuel consumption will be higher since the MID will translate lower distance travelled with same amount of fuel. I believe you are saying Fuel Efficiency (not consumption) will be calculated lower.
    Yep, the actual will be different from the computed. The computer will interpret a lower distance than the actual traveled since based sya sa rotation ng tire at hindi sa GPS location for example.
    As an analogy, let's say ang hakbang ko is one foot and that is what the computer kows. What I do is lakihan ko yung hakbang ko to 2 feet per hakbang. Now if I do 10 steps, my actual distance will 20 feet but the computer will "think" 10 feet lang.
2013 Mitsubishi Mirage
