Results 5,741 to 5,750 of 5870
October 3rd, 2015 02:57 PM #5741
Tire pressure is like inflation, it lessen in value as time pass by
October 3rd, 2015 03:12 PM #5742
I see variation in tire pressure at around 2 psi (going up) thru my tpms when you use it in hot weather.
October 3rd, 2015 03:35 PM #5743
October 3rd, 2015 03:42 PM #5744
Nelany, thats a fleeting moment, it will never last long..pressure will go up as temperature surge
Bottomline is tires deflate as a function of time from the moment you inflate it up to the time you reflate itLast edited by kisshmet; October 3rd, 2015 at 03:45 PM.
October 3rd, 2015 08:51 PM #5745
Since 2 psi lang ang increase ng pressure so me idea na kung anong max pressure sa highway. Better install a TPMS if you want to monitor yung tire pressure mo.
October 4th, 2015 10:03 AM #5746
TPMS is not practical for every car owners
The point you raise about a slight increase in pressure on a warm temperature or as the tire roll and get warm is a good point to remember
To prevent bursting the tire while on the run, a user should provide allowance if one intends to pump air at a maximum level. For example if the max tire pressure is 44 then 42 is about right not to over inflate the tire to provide allowance due to increase in temp
October 4th, 2015 10:16 AM #5747
October 4th, 2015 10:37 AM #5748
Yup TPMS is not practical for all, but if the owner is keen on the tire pressure he may install one. Meron owner na metikuloso sa ganyan so installing one will be the answer.
October 4th, 2015 10:46 AM #5750
Thanks sir, ngayon lang talaga ko naging metikuloso sa tire pressure as i said before eto lang kasi yung nakita kong may recommend psi na halos sagad na sa max. Sa usual ride ko 10-15psi yung agwat sa recommend.
Hello po, new lang po me sa Car Industry Me and my Dad purchased a 2nd hand po na toyota innova...
