Results 5,731 to 5,740 of 5870
October 3rd, 2015 09:08 AM #5731
- 52,684
October 3rd, 2015 09:36 AM #5732- - - - - - - - - - - - - - - - - - - - - -
as long as the specifications indicated on the tire's carcass are not violated, the tire should survive the experience.
but the over-inflation might figure negatively on the vehicle's suspension, etc..
but yess. over-inflation does seem to soften the steering feel..
i myself, add +2 psi ...
October 3rd, 2015 10:08 AM #5733
Feeling ko kasi parang over-inflation yung nasa recommend. Sa Adventure kasi 26 front 36 rear tas ang max psi ng gulong is 50psi. Samantalang to 36 front 33 rear tas max psi ng gulong is 44psi. Yung dating lancer ko kasi 30 front & rear kaya medyo nanibago talaga ako. Ask ko lang po pag hiway drive at the speed of 90-100kms. Ilan po kadalasang nadadagdag sa hangin sa gulong?
October 3rd, 2015 10:13 AM #5734
Masyado matagtag yung 35psi sa akin. I normally hover between 32 to 33 psi lang.
- Aug 2012
- 2,767
October 3rd, 2015 10:51 AM #5735It is the ambient temperature that you should consider, not your driving speed.
1-psi/10F = 1-psi/5.5C
Morning temperature = 27C
Cold tire air pressure = 36 psi
Case 1.
Afternoon temperature = 32C
Change in temperature = 32C - 27C = 5C
Increase in tire air pressure = 5C x 1 psi/5.5C = 0.9 psi
Tire air pressure = 36 psi + 0.9 psi = 36.6 psi
Case 2.
Afternoon temperature = 40C
Change in temperature = 40C - 27C = 13C
Increase in tire air pressure = 13C x 1 psi/5.5C = 2.36 psi
Tire air pressure = 36 psi + 2.36 psi = 38.36 psi
So 36 psi sa front is safe even if ambient temperature is 40C.
Case 1.
Case 2.
October 3rd, 2015 12:19 PM #5736
- Aug 2012
- 2,767
October 3rd, 2015 12:50 PM #5737Para hindi ka kabahan, buy yourself a tire air pressure gauge. Actually, dapat meron ka na nito.
Inflate your front tires to 36 psi in the morning and then after you use the vehicle, measure the tire air pressure again. At least yan, actual mo makikita kung umaabot ka ng 44 psi.
- 52,684
October 3rd, 2015 01:23 PM #5738
- Aug 2012
- 2,767
October 3rd, 2015 01:44 PM #5739"Inflate your front tires to 36 psi in the morning" >> This is the cold tire air pressure.
"and then after you use the vehicle, measure the tire air pressure again." >> This is the hot tire air pressure.
The purpose here is to know the maximum air pressure inside the tire during normal use.. since according to radz15, tire sidewall indicated 44 psi as maximum for his tires.
- 52,684
October 3rd, 2015 01:48 PM #5740
Ang tagal na ibinalita yang ban. Tapos warning pa ang ginawa first few days. Yung mga nahuli pa...
E-bike / E-trike ban details released by MMDA
