Results 4,951 to 4,960 of 5870
May 24th, 2013 08:29 PM #4951
^^^ You might have shifted then released clutch suddenly and engine couldn't handle the load.
- 52,698
May 25th, 2013 12:22 AM #4952i am not sure if engines with CVT shut down if they can't take the load. i think they just shift to low gear.
i have an older lancer with CVT. the engine has never died on me, even as i sometimes tried to make it die..
i think something's fishy here...Last edited by dr. d; May 25th, 2013 at 12:25 AM.
May 26th, 2013 07:15 PM #4953
Last week end, traveled to Tarlac from Laguna and back the same day. Computer shows an average of 6.2 to 6.4. From Laguna, nagpa full tank up to auto lang. Sa SLEX before santa rosa, pa full tank ulit. Auto lang. Computed a little over 16,1 km per liter.
- Apr 2013
- 280
May 27th, 2013 03:32 PM #4954
- Jan 2013
- 39
May 27th, 2013 10:54 PM #4955Mga sir, help naman po, 5 months na ko nag da-drive ng Mirage ko, CVT a/t. napa first 1000 kms ko na din sya. kaso hindi po ako masyado maalam sa cars since first car ko to. Ano po ba ang ilalagay dun sa radiator ba yun, coolant po ba? or alin dun ung sa water? And kelan ko po ba malalaman kung kelan na lalagyan ng coolant or water? Sorry am really not that knowledgable to cars but am starting to ask na since I own one and I need to learn na. Thanks in advance
May 27th, 2013 11:55 PM #4956
What can you guys, say about the upcoming new Mirage fighter from Toyota? The Ayga.
http://tsikot.com/forums/toyota-cars...ta-ayga-93678/
- Dec 2011
- 218
May 27th, 2013 11:59 PM #4957
- 52,698
May 27th, 2013 11:59 PM #4958
- Jan 2012
- 5
May 28th, 2013 05:42 PM #4959
May 28th, 2013 05:46 PM #4960
If it's a concentrate then dilute according to the label. If it's premixed then use it as is.
And while your car is under warranty I suggest let the casa do the refilling during routine PMS. Some coolants don't play well with others and may cause damage when mixed. Since you used something not recommended by the casa that will be grounds for them not to honor your engine warranty.
And tama si HondaWay di halos nababawasan yan. After 4 PMS on my Vios the casa only refilled it once with around 100ml of coolant.Last edited by JohnM; May 28th, 2013 at 05:51 PM.
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
