Results 3,171 to 3,180 of 5870
- Jun 2012
- 4,448
December 5th, 2012 12:23 PM #3171
- Oct 2003
- 176
December 5th, 2012 12:23 PM #3172doon sa mga nagmemenos sa gas.
bilhin nyo to. nasa sulit lang...50k negotiable...tatay ni mirage...color yellow pa.
kung nasa 500k budget mo eh di may 450k ka pa na pang gasolina........take note, yung 50k negotiable pa.
sulit talaga.
- May 2005
- 70
December 5th, 2012 12:26 PM #3173
- May 2005
- 70
December 5th, 2012 12:30 PM #3174
- Mar 2007
- 224
December 5th, 2012 12:33 PM #3175
- Oct 2009
- 249
December 5th, 2012 12:36 PM #3176
- Jan 2008
- 380
December 5th, 2012 12:47 PM #3177As consumers kelangan din talaga nating gamiting ang ating isip, di lang yung praise na lang ng praise, bad yan.
Sir Caloy, yung mga fuel test sa Mirage eh lahat naka set up for Euro 4 compliance at naka-target din for fuel economy which will give monetary and other grants both for Mits and the consumers like tax exemptions and lower car registration fees. Here in the Philippines Euro 2 lang po ang set-up ng Mirage. I am thinking that aside from pulling out economy-system-gadgets (like regenerative braking, auto stop n go, alternator management, etc) and fuel quality, there maybe changes also in ECU settings of PH Mirage which if modified can give us better fuel economy.
Napansin ko rin that compare with some other cars the the ratio of Mirage engine rotation per rotation of tire is higher though those other cars produce lesser power and torque. Kung lakihan kaya natin yung overall circumference ng tires di kaya mas matipid ito without serious negative effects
sa torque and acceleration. Sabagay, it needs a dyno para ma-analyze yung power band ng Mirage at different engine speeds and loads.
- May 2005
- 70
December 5th, 2012 12:48 PM #3178
- Nov 2012
- 50
December 5th, 2012 12:54 PM #3179Positive or negative feedbacks man lahat ng kotse may ganun and Mirage is the first subcompact of Mitsubishi which has "Good FC" and "cool stuff inside and out" and looks na cool sa generation ng mga subcompact. Nasa sa inyo kung maniniwala kayo at kung gusto pa rin kumuha nitong kotse nato.. You almost heard/ seen every feedbacks from different owners and variants of mirage. Basta ako kukuha pa rin. Di mo malalaman kung di susubukan..
Chill lang..
Peace! =))
- May 2005
- 70
December 5th, 2012 12:55 PM #3180Napansin ko rin that compare with some other cars the the ratio of Mirage engine rotation per rotation of tire is higher though those other cars produce lesser power and torque. Kung lakihan kaya natin yung overall circumference ng tires di kaya mas matipid ito without serious negative effects
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
